Thread: Sub amp problems. Possible ground location??
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Sub amp problems. Possible ground location??
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Ok the amp is an audioque 1200d which will pull 100-120 volts full tilt. So just making sure
  2. #22 Re: Sub amp problems. Possible ground location??
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    Quote Originally Posted by comatoast View Post
    *amps
  3. #23 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Well everything seems ok now. What I thought was a bad ground or bad amp that was making my subs sound like poo actually ended up being a bad coil on one of the subs. And seeing as they were wired in parallel it was affecting both. Now it's time for a recone or a new big single enclosure
  4. #24 Re: Sub amp problems. Possible ground location??
    Yoga city
    stay with 2 subs if you can, more cone area easily.
  5. #25 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Yea if I didn't need a re come I would. A big box with some power should be just fine for now.
  6. #26 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    Anyone on here have TL #s? I dont know if its my setup, car or both, but these dc lvl 3 12s got a 147 in my 96 grand am gt and was pretty brutal.. this to me sounds like mid 30s at best . even after a w6 swap with more power..
  7. #27 Re: Sub amp problems. Possible ground location??
    Sep 2011
    Arkansas
    TL #s won't help much, without knowing how they metered (sealed or outlaw), EVERY mod done to the car, where everything was (opening and closing a glovebox sometimes makes big differences, as well as many other stupid things), and quite a few other variables. Not to mention what frequency your burp was at, power used, nominal ohm load, ohm load after rise, etc. etc. etc. Long story short... mess with it. New enclosure, new locations, etc. etc. etc. By your request of TL numbers, I'm assuming you're acquainted competitions somewhat, and are more than aware of what I've stated here...
    That being said, in an 04+ I'd either be running 2 15s or a single 18 myself.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  8. #28 Re: Sub amp problems. Possible ground location??
    Nov 2012
    MN
    You got way to texhnical. TL numbers. Legal on the dash. Just looking for an average. I know deadening the trunk and doors are a plus and the roof will actually loose db but sound better. I don't do burps. Been there done that and it's boring. Deep clean bass is what I want
  1. bad ground ??
    By GTPgurl in forum General Tech Discussion
    Last Post: 03-04-2011, 09:19 AM
  2. Amp Ground
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 08:14 PM
  3. Engine wiring harness ground location?
    By PCweber in forum General Tech Discussion
    Last Post: 09-24-2009, 01:10 PM
  4. Bad Ground???
    By jjokrm in forum General Tech Discussion
    Last Post: 01-25-2009, 07:44 PM
