Thread: standard vs bose head units
Results 1 to 2 of 2
  1. #1 standard vs bose head units
    Dec 2012
    chicago burbs
    I just purchased a 2001 Grand Prix GTP to flip. The prior owner thought he had thrown a rod, but turned out to be a collapsed lifter that I managed to get pumped up again. The car is very clean and straight with only 105K miles on it.. I am going about fixing all of the little problems I am finding in order to sell the car on. The radio ( Bose system ) only has the right channel, front and rear. I can hear the bass out of the rear left speaker but very faintly. I just changed out the Bose amp with no change so I am assuming it is the head unit that went bad. The head unit looks like any of the other head units I can find on E bay. Are they the same? Do I need to find a head unit from a Bose system car? I just want everything to work as intended. I want to retain the steering wheel controls and don't feel like messing with aftermarket stuff. The key word here is fix it CHEAP!
    Thanks for any and all input.
    I live here. DirtDog's Avatar
    Jun 2012
    If u find another Bose head unit that uses the same type of plug in or wire harness in the back of radio u can just swap em out easily. If its a different brand u would need to switch the wire harness behind dash to fit different brand radio. Its not hard to switch
    Sent from my pager using Morse code. ... .. ... ....
  1. Anyone know how to fix head units?
    By gtpeddie in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2012, 08:01 PM
  2. Is it possible to swap head units?
    By firstdue in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2012, 05:40 PM
  3. 2 din head units?
    By 99PontiacGTP in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2011, 10:27 PM
  4. Bose Audio or Standard?
    By FriboRage in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 04:59 PM
  5. Head units
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 01-28-2009, 11:21 PM
