Thread: Wiring AfterMarket Head Unit Bose System
Results 1 to 6 of 6
  1. #1 Wiring AfterMarket Head Unit Bose System
    GT Level Member BrendanMurphy's Avatar
    Jan 2012
    Keswick, Ontario
    I picked up a Sony Mex BT3100P head unit cheap. I have the bose system so i know i need the pax adapter to hook into it. I have the faceplate, antenna adapter and standard gm wiring harness ( ZZP actually sent me 2 lol by accident ). Any tips or advice to give me a guide would be nice too.
  2. #2 Re: Wiring AfterMarket Head Unit Bose System
    Yoga city
    color coded wire, should be pretty easy man.
  3. #3 Re: Wiring AfterMarket Head Unit Bose System
    Telling us your year is always cool.
    Don't forget I the bose amp wire, cause w/o that..you get no sound.
  4. #4 Re: Wiring AfterMarket Head Unit Bose System
    Jan 2012
    Keswick, Ontario
    It's a 40th 2002 GTP. People have told me the adapter to keep the amp i need to tap into the speakers at the door or something.
  5. #5 Re: Wiring AfterMarket Head Unit Bose System
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    In the door? For me with bose it was the pink wire on the small harness, wire it up to the yellow.
    Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
    Albert Einstein
  6. #6 Re: Wiring AfterMarket Head Unit Bose System
    Feb 2010
    TN
    Not to hijack the thread but I got a bose set up from a 99 GTP to put in my 97 GT fronts were a direct swap worked great rear 6x 9's had to change the connect and they are god but I can't get any sound from those small round rears any idea whats wrong?
  1. OEM Head Unit Wiring
    By blackmoose in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2012, 09:55 PM
  2. Hooking up Aftermarket Deck in a '03 with Bose factory system/Amp
    By Kahn in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 10:49 AM
  3. Installing a aftermarket deck on a Bose system.
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 09:19 AM
  4. Aftermarket Head Unit Wiring Help?
    By beams75 in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2011, 04:52 PM
  5. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
