Okay. I installed a Autopage RS-860 alarm with remote start a month ago in my 99 Montana. I bought it new like 5 years and 3 cars ago(So I procrastinated on installing it a little). I had everything I needed to install it and to bypass the pass key 3 system. And it works great! No problems remote starting the minivan at all. Starts every time on the first crank unless it sat for a bit. Then it has to crank again, but starts(it does that even with the key, fuel pump check valve issue). My problem I am having is, every so often after I remote start it the pass key light comes on. It starts up and runs and drives. But the light stays on for about 3 key cycles. Then the light shuts off. Seems like it does that to tell you there is something wrong with the pass key system. But if there was something wrong with it, wouldn't it cause the car not to start? It never does that when I use the key. Only when I do the remote start. So is there something else telling the pass key thing that there is no key? Maybe it's tied into the little switch for the key in ignition door chime? Any thoughts? Thanks Adam
