Thread: Electrical Gurus step in (relays)
Results 1 to 2 of 2
  1. #1 Electrical Gurus step in (relays)
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Ok so i want to run both highs and lowes at same time on the regal when highs are selected.
    Yes regal uses 9005 and 9006.
    Strang thing is wire harness at bulb both sides are positive until lights are commanded then one turns to ground
    Right now i already have a harness for low hids.
    Correct me if i am wrong as how i would wire this.
    To start:
    85 and 86 = coil
    30 is main power input
    87 is main power output.
    So from high side i would build a relay use the cars bulb side harness to control the coil 85 + 86 which will both be HOT until highs are commanded then one will ground activating the relay. Then from main power out (87) it will feed both highs and feed a trigger wire back to low relay ( 86) to also trigger the lows.
    Does this sound correct or is there a better way to do this with out having to rewire the highs completely
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  2. #2 Re: Electrical Gurus step in (relays)
    SE Level Member blackbonnie's Avatar
    Jan 2009
    grand rapids, MI
    sounds decent to me. as long as yrou sure one grounds out, i dont see a problem
  1. Website/Photo design gurus
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 10-12-2008, 01:37 PM
  2. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
  3. Any wiring gurus
    By archemedes in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2008, 06:00 PM
  4. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
  5. Electronics/Google Gurus step in!
    By TyroElite in forum General Tech Discussion
    Last Post: 02-17-2008, 10:01 AM
