Thread: hids
Results 1 to 8 of 8
  1. #1 hids
    antioch ill
    put my hids in tonight. but even when i had the stock bulbs in it the right hand side projector projected the light at two different distances. left projector is perfectly fine what casues this
  2. #2 Re: hids
    Jun 2011
    Adjust your headlights sir.
  3. #3 Re: hids
    antioch ill
    i did the they are at the same level but the right one cuts off at a certain distance on half of it and shoots to the same distance as the left
  4. #4 Re: hids
    Jan 2012
    Philadelphia
    Quote Originally Posted by E IN v Y View Post
    correct^
    mine do the same but i dont worry about it
  5. #5 Re: hids
    Jun 2011
    You have stock projectors?
  6. #6 Re: hids
    antioch ill
    no i have spyder ccfl projectors with the halos
    and eddie the only problem i have with it is that most of the roads by me at night have no traffic and dont have lights on them so i dont like having a blindspot like that
  7. #7 Re: hids
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    mine have the same problem i find they work better when you take out the blocking plate
  8. #8 Re: hids
    SE Level Member bziggy58's Avatar
    Apr 2011
    Minnesota
    To matt palm. I seen you have the same projectors as me. Did you just use the regular h1 HIDs? I was told they don't fit. I'm looking to get HIDs in my lights like yours. Did you get a canceller cable or relay?
  1. what HIDs should I use on these?
    By Joshmoshh in forum Visual/Body Modifications
    Last Post: 04-07-2012, 02:08 AM
  2. My HIDs
    By SliceTheRice in forum Visual/Body Modifications
    Last Post: 01-09-2012, 06:02 PM
  3. best HIDs?
    By Points70 in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2011, 01:49 PM
  4. Those who have HIDS
    By trenaro in forum Visual/Body Modifications
    Last Post: 12-05-2010, 06:51 PM
  5. Which Hids
    By krippled in forum General Tech Discussion
    Last Post: 01-31-2008, 11:17 PM
