Thread: Tweeter install
Results 1 to 5 of 5
  1. #1 Tweeter install
    Jersey
    I want to improve the highs in my system so im looking into buying tweeters. Here's my mids and highs setup:
    (1) Alpine Head Unit
    (1) Pair of Alpine 5.25 Type R for front
    (1) Pair of Alpine 6.25 Type R for rear
    (1) Eclipse XA 4200 4 channel amp (100 rms x 4)
    Now im very interested in the Polk db 1001 as i heard they're pretty loud. And i see that they have an in line crossover attached to it. I was wondering if i can use my stock wires to hook the Alpine speakers back to the head unit and hook the tweeters straight to the 4 channel amp? The amp only has a hpf that goes to 500 hz only. So im not sure if this would work...help and advice is needed. Sometimes you think you know it all when you dont smh
  2. #2 Re: Tweeter install
    antioch ill
    get 6x9 for the rear
  3. #3 Re: Tweeter install
    Topeka, KS
    I did 6.5's in the rear and i mounted my tweeters in the rear deck speaker cover just used a whole saw and marked where i wanted them.
  4. #4 Re: Tweeter install
    Jersey
    I'll get the locations later but in the meantime im worried about the wiring part. What should i do??
  5. #5 Re: Tweeter install
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    run your own wires with crossovers
  1. New Front Speakers, Had To Disable Stock Tweeter?
    By SuperSport in forum Audio, Security & Visual Electronics
    Last Post: 08-28-2012, 04:51 PM
  2. best Tweeter mounting locations?
    By ColeTrain84 in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2012, 08:53 PM
  3. tweeter mount help needed
    By onetyme77 in forum Audio, Security & Visual Electronics
    Last Post: 01-09-2011, 10:34 PM
  4. Tweeter Pods
    By windowrattler in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2011, 11:47 PM
  5. Tweeter Installation
    By Burgundyman in forum Audio, Security & Visual Electronics
    Last Post: 08-13-2008, 12:37 AM
