Thread: LED Lights Under Seats
Results 1 to 18 of 18
  1. #1 LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    I'm looking to buy some sort of blue LED bar to place under my seats facing towards the rear of the car. My question is what product do you recommend I buy and what should I use to power the LED bars so that there are no visible wires running through the car?
  2. #2 Re: LED Lights Under Seats
    GT Level Member 99GTRED's Avatar
    Oct 2011
    Grand Rapids, Michigan
    they have LED strips at autozone that has 3M tape on the back, thats where i got mine
    99' GT: CAI, exhaust, 110k, totaled
    06' GP GT Supercharged, 89k, sold
    11' Scion tC: DD
    99' Trans Am WS6
  3. #3 Re: LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    What did you hook them up to for power? By the way those look really nice
  4. #4 Re: LED Lights Under Seats
    Oct 2011
    i just picked a fuse in the glove box then used a bolt on the shift cable for the ground, then i got a power switch from a meijer store
    11' Scion tC: DD
    99' Trans Am WS6
  5. #5 Re: LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    How much did the LED bars cost?
  6. #6 Re: LED Lights Under Seats
    Oct 2011
    Alpena/28 in. red colorful LED light (77016) | LED Exterior Accessories | AutoZone.com
    im pretty sure thats what i got. ive seen them in green red and blue. i guess it depends on what store you go to
    11' Scion tC: DD
    99' Trans Am WS6
  7. #7 Re: LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    How would you suggest powering ones that I put under the seats?
  8. #8 Re: LED Lights Under Seats
    Oct 2011
    you could do the same you just have to get longer wire. you can tuck everything under the center console, it all pops out
    11' Scion tC: DD
    99' Trans Am WS6
  9. #9 Re: LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    Alright, thank you!
  10. #10 Re: LED Lights Under Seats
    Topeka, KS
    I might be a little out of line... I also did this when I was in HS with my truck. Do realize that any blue or red (Emergency Colors) if visable flashing or not flashing outside of the cabin can warrant you a ticket in any state.
  11. #11 Re: LED Lights Under Seats
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I wouldn't stick the lights from the front under the seats. Put them under your dash. I will post up some pics later on how I did it and then for the back seat just go to like meijer and get 3m velcrow and put a strip of it on the back side of the lights and they will stick to the bottom of the seat with no problem
  12. #12 Re: LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    I was going to have the ones under the seats facing back towards the passengers in addition to the ones under the dash facing forward to the front seats. And I would very much appreciate those pictures, thanks for the advice. Also I am aware that those are emergency colors, I've had a friend who got pulled over because he had two blue LED bars just up in his back window. I don't think that these will be noticeable from the floor outside the car though
  13. #13 Re: LED Lights Under Seats
    Nov 2008
    Waterloo, Iowa
    If you use LEDs and have the aimed properly, worst case is at night there might be a faint red (or whatever color) glow coming from inside the cabin. Probably no worse than doing an LED swap on your dash lights and gauge cluster. So I wouldn't worry about it.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    That's how I did my back seat So I didn't have to worry about them getting caught on someone's feet
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  15. #15 Re: LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    Is there an easy dash illumination cable to get at for this that you could just split so that way they turn on when the dash lights do automatically when it's dark?
  16. #16 Re: LED Lights Under Seats
    Nov 2008
    Waterloo, Iowa
    just splice it into the gauge cluster lights or so. even the light switch. then you're all good to go.
  17. #17 Re: LED Lights Under Seats
    Jun 2011
    Nah brahs!
    F That auto zone BS... it expensive.
    Go to amazon and get yourself an LED GLOW kit.
    4pc. Multi-Color 7 Color LED Interior Underdash Lighting Kit : Amazon.com : Automotive
  18. #18 Re: LED Lights Under Seats
    Sep 2012
    Cedar Rapids, Iowa
    Thank you Sean!
  1. Shifting Lights , AC Lights, Door Lights All Went Out?? Grand Prix 04
    By Levi Hardin in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2012, 12:49 AM
  2. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  3. 2001 GTP - Replacement rear tail lights and front head lights
    By zguy in forum General Grand Prix Discussion
    Last Post: 01-09-2012, 06:21 PM
  4. Swapping powered '97 seats with '01 seats
    By 2kgtp in forum General Tech Discussion
    Last Post: 02-21-2011, 11:24 PM
  5. Unpowered seats to powered seats? A possibility?
    By GrandPrixFan in forum General Tech Discussion
    Last Post: 09-08-2010, 10:31 AM
