Thread: High Amp Alt vs. Bigger Cap
Results 1 to 20 of 37
  1. #1 High Amp Alt vs. Bigger Cap
    GT Level Member adidasdude1061's Avatar
    Jul 2008
    P-Town, MN
    So, I have stock alt. with Alt boost and rewire. the amp has 40x4 fuses. I don't seem to have any problems with the alternator at all. Does it make since for me to get it boosted to 160 amps? Or does it make more since to just get a bigger cap? I have 2 farad right now. The lights do dim.
    '97 BLACK GTP--Chrome K&N CAI--3.5" MPS--3" RT Cat Downpipe--180*Tstat--Tuned PCM--Alpine 9886--Kicker Amp - 2 12" Kicker L7's--ALT boost&rewire
  2. #2 Re: High Amp Alt vs. Bigger Cap
    GT Level Member BackInBlack's Avatar
    Vermont
    A higher amperage alternator is ALWAYS better than a capacitor. As well as running both your amp's power and ground wires straight back to the battery itself.
    The GPs are long gone...
  3. #3 Re: High Amp Alt vs. Bigger Cap
    Jul 2008
    P-Town, MN
    will 160amp alt be good enough if I have a JBL amp 1500w RMS (4x40Amp fuses) 1500wRMS Sub & a 2 farad cap?
  4. #4 Re: High Amp Alt vs. Bigger Cap
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    Its enough, Get a bigger battery and run a 1 gauge wire from your ALT to BATTERY, BATTERY GROUND TO CHASSIS, AND ENGINE TO CHASSIS (it called the big 3) Official CarAudio.com Big 3 Thread - Car Audio Forum - CarAudio.com
    2008 Grand Prix + Kenwood KVT815DVD, Kicker SXRC Controller, Kicker SX 1250.1, Kicker (2) 12" L7's, Kicker SX 900.4, Kicker RS65.2 Components in front. Infinity Refs 9623i 6X9's in rear
  5. #5 Re: High Amp Alt vs. Bigger Cap
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    you should be good as you are...2 12" L7s on a 1000w kicker amp, my lights barely, barely dim...i have a cap, NO alt. re-wire or boost, i do have a brand new battery from autozone that costed $119....but if u still wanna upgrade i'd say go with a good battery if yours has some age on it..... but dang dude ur already running 2 caps? wtf u beatin' with?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  6. #6 Re: High Amp Alt vs. Bigger Cap
    Jul 2008
    P-Town, MN
    Went with the rebuilding option - 160 amp now, and am more then happy with my setup. Speakers don't cut out, no dimming at all, Overall greatness achieved
  7. #7 Re: High Amp Alt vs. Bigger Cap
    Aug 2008
    Fayetteville, NC
    glad to hear
  8. #8 Re: High Amp Alt vs. Bigger Cap
    GT Level Member reinke's Avatar
    Oct 2008
    cleveland, ohio
    i will be the first one here to post it. DO NOT USE A CAPACITOR. they are useless. but a small bettery instead. either a powermaster, optima, or a kinetik.
  9. #9 Re: High Amp Alt vs. Bigger Cap
    Aug 2008
    Michigan
    Quote Originally Posted by reinke View Post
    ^I second that ^
  10. #10 Re: High Amp Alt vs. Bigger Cap
    Aug 2008
    Fayetteville, NC
    there not useless
  11. #11 Re: High Amp Alt vs. Bigger Cap
    the light dimming is essentially caused by the difference in voltage between the battery and the alternator. Alternator is about 14 volts battery is 12 volts...so all electronics run @ 14 volts when the car is running, but when you consume all the current the alternator has to offer then if falls back on the battery which has plenty of reserve power, but at a lower voltage so you get light dimming on hard bass notes (notice your lights do not dim as bad with the car off?)... Caps don't make power, but they do help buffer out the light dimming issues. If you simply don't have enough power than a bigger alternator is always better. But bigger alternators don't last nearly as long as the originals....More batteries will only give you longer reserve power for 'key off' listening time, when the car is running those batteries create an additional load on the alternator making your problems worse. Do not add more batteries to an over-taxed system.
  12. #12 Re: High Amp Alt vs. Bigger Cap
    SE Level Member blackbonnie's Avatar
    Jan 2009
    grand rapids, MI
    times eleventybillion
    Quote Originally Posted by offroadfury6 View Post
    there not useless
    they are useless, unless you are competing for a sound quality world championship, they are useless.
  13. #13 Re: High Amp Alt vs. Bigger Cap
    Jul 2008
    sumter,south carolina
    a capacitor is fine for minor powerloss
    02 GTP with mods 05 GP for DD
  14. #14 Re: High Amp Alt vs. Bigger Cap
    Oct 2008
    cleveland, ohio
    yeah only if you have a 3 watt amp for your tweeters or something. 9 times out of 10 it will hurt the performance of you audio system. caps raise your ESR to a unsafe level. get a extra battery.
  15. #15 Re: High Amp Alt vs. Bigger Cap
    Oct 2008
    cleveland, ohio
    true but very false at the same time. adding extra batteries will help with the car off but also give oyu more reserve power. basically once you extra batteries are fullt charged it will take longer for your lights to dim. i have 3 extra batteries (4 total) in my truck and my lights do not dim at all. i am also running a stock 130amp alt. adding extra batteries will help drastically.
  16. #16 Re: High Amp Alt vs. Bigger Cap
    true but very false at the same time. adding extra batteries will help with the car off but also give oyu more reserve power. basically once you extra batteries are fullt charged it will take longer for your lights to dim. i have 7 extra batteries (8 total) in my truck and my lights do not dim at all. i am also running a stock 130amp alt. adding extra batteries will help drastically.
    taken from Car Electronic Basics
    Many people are under the impression that adding a second battery will cure their electrical problems. If one battery is good then two must be better. Right? Wrong. Remember that the function of a battery is to start the vehicle and to provide power when the vehicle is not running. The only thing a second battery will help you with is "parking lot" listening time. Basically it will provide you the additional capacity to run your stereo longer without starting the vehicle. After the vehicle is started the second battery becomes another load on an already overworked alternator.
  17. #17 Re: High Amp Alt vs. Bigger Cap
    Oct 2008
    cleveland, ohio
    well i am telling you from over 10 years of car audo experience that statement is false. my voltage sat at 13.6 idle before i added any batteries. after i finished adding all my batt's my truck now idles's at 14.7. when i rev to 2000rpm when i compete for 30 seconds full tilt non stop the whole time my voltage does not drop below 13.8 now. adding batteries will help you voltage PERIOD. go to stevemeadedesigns.com and ask around.
  18. #18 Re: High Amp Alt vs. Bigger Cap
    I agree, more batteries = more current. The big problem is you will overwork your alternator and it wont last very long trying to charge up all those batteries. It may seem like its helping but remember batteries store power, they do not make it. If you dont run a H/O alternator you wont be able to keep your alternator running for more than 5-6 months at a time...I was an installer myself for over 5 years and even did a 4 month mobile electronics course. Anybody who went ahead and added a second or third battery always ended up with dead alternators, especially GM alternators which are flaky to begin with. Not to mention a regular battery weighs a good 40-50 pounds...not good for the gas millage
    In your situation with audio competitions I think more batteries is best for you, because you will get a **** load of current out of them for that 30 second blast. For the average person another battery is just not at all necessary for a simple light dimming issue. Run up to a 2F cap (which will discharge high current very quickly for a short period of time, much faster than a battery can), if you still have issues, step up your alternator output a bit.
  19. #19 Re: High Amp Alt vs. Bigger Cap
    Aug 2008
    Fayetteville, NC
    yeah a second battery is great but its not something you would Really need! just depends what kind of audio you are running, my kicker system is fine with a cheap cap.
  20. #20 Re: High Amp Alt vs. Bigger Cap
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    Home of the Batcap
    this is what you need right here. I know tons of people using them. you can find them on ebay if you don't want to buy brand new.
  1. Making a bigger cubby hole in center console [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 02-28-2009, 11:11 PM
  2. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
  3. Gas Prices Are So High........
    Last Post: 06-25-2008, 03:37 PM
  4. I think I am going to need a MUCH bigger hood now!
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 05-14-2008, 10:29 AM
  5. tuning high MPH
    By deangtp in forum PCM Tuning
    Last Post: 04-17-2008, 07:43 PM
