Thread: Poked hole in sub while installing it, what should i do???
Results 1 to 19 of 19
  1. #1 Poked hole in sub while installing it, what should i do???
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    hey guys i ordered new subs on amazon and recieved them today after a week. excited to get them in i went right to work. got the first one in no problem what so ever. second one in i had 3 screws left drill slipped and i poked a hole straight into it. what should i do? should i take it to an audio store and try and get it repaired? or i was also strongly considering poking a hole in the box it came in and sending it back to amazon demanding a replacement. what do you guys think?
    Donating Users onetyme77's Avatar
    texas
    Did they come with any type of warranty? If so send them back. If you are stuck with them see what an audio shop can do. I used to work at one 10yrs ago, things have changed, so they may can repair it. I've actually done the same thing but worse, I put some sealant (rubbery type) on it and keep on bangin.
    Sent from my SCH-I535 using Tapatalk 2
  3. #3 Re: Poked hole in sub while installing it, what should i do???
    Out West
    Duct tape.
    Whine with your Cheese?
  4. #4 Re: Poked hole in sub while installing it, what should i do???
    mi
    You screwed it up so you want them to replace it? That's this generation in a nutshell I guess.
  5. #5 Re: Poked hole in sub while installing it, what should i do???
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    your screwed straight up if you dont have a warranty. They sound nasty with a whole. Best thing is rubber sealant or some ghetto as duck tape. Either way eventually the air is going to blow that whole back open again
  6. #6 Re: Poked hole in sub while installing it, what should i do???
    GTX Level Member blackflag's Avatar
    Virginia
    LOL!
    I laugh because I did this with my first car. i just took it back and they replaced it.
  7. #7 Re: Poked hole in sub while installing it, what should i do???
    Virginia
    Quote Originally Posted by Nixon View Post
    Duct tape.
    = west virginia chrome.
    Do it
  8. #8 Re: Poked hole in sub while installing it, what should i do???
    Mar 2012
    San antonio
    lol yea duct tape them *****s. there in your trunk no one will know
    texas
    Duct tape alone will not hold, use a good permanent rubber sealant. That hole is so small u should be OK, till u get a replacement.
    If a car tire can be patched, I'm pretty sure that u can find something to help u out
  10. #10 Re: Poked hole in sub while installing it, what should i do???
    Antioch, IL
    patch the hole and call it a day. been there done that, beat the **** out of that sub and it kept kickin
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: Poked hole in sub while installing it, what should i do???
    I used clear finger nail polish when i did this to mine. Worked for years until i sold them.
  12. #12 Re: Poked hole in sub while installing it, what should i do???
    Jul 2010
    Coquitlam,BC,Canada
    I got a tear in the mid-range in my truck years back. I used some flexible silicone on both sides and it worked just fine.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: Poked hole in sub while installing it, what should i do???
    Houston
    Just put a dab of clear silicone on it, let it dry fully and forget it was even there. Stay away from rubber cements because some of them will eat up that foam.
  14. #14 Re: Poked hole in sub while installing it, what should i do???
    Jan 2012
    Philadelphia
    silicone thats what i did i found a pair of 2006 12" pioneer premiers for $60 put some black silicone on there works good as new
    i heard the chemicals in the silicon can eat away at the sub material but im not sure how true it is because it works fine for me and has been like that for a year
  15. #15 Re: Poked hole in sub while installing it, what should i do???
    Nov 2011
    Decatur
    thanks for all the suggestions guys
  16. #16 Re: Poked hole in sub while installing it, what should i do???
    Yoga city
    i love when this happens, patch it with something elastic so it can stretch as the sub v max's.
  17. #17 Re: Poked hole in sub while installing it, what should i do???
    Out West
    Quote Originally Posted by siLversLeigh View Post
    This.
  18. #18 Re: Poked hole in sub while installing it, what should i do???
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    take the sub out... E6000 just a dab around the hole, then gorilla tape it.
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  19. #19 Re: Poked hole in sub while installing it, what should i do???
    I live here. TLSheff's Avatar
    Silicon it if you want a cheap fix, but once a hole is there, it will be weak there and eventually will tear more from use (at least from my experience). I have done the same and silicon'd it up but with hard use they ripped more over time.
    If you want it done right you can call the manufacturer of the sub and explain what happened and they may warranty replace the sub for you, if not they can give you the info on the replacement excursion around the sub.
  1. Who knew you could drift a bike...and something for Mr. Poke
    Last Post: 01-16-2012, 08:54 AM
  2. hole in VC
    By gtpinsc in forum General Tech Discussion
    Last Post: 01-23-2011, 10:50 AM
  3. so some a$$ hole wants to fight me...
    By mezzoni in forum The Rant Forum
    Last Post: 07-19-2010, 01:27 PM
  4. Could this be a hole in #1 piston?
    By guys00gtp in forum Off Topic Discussion
    Last Post: 06-24-2010, 03:27 PM
