Thread: Daytime running lights
Results 1 to 19 of 19
  1. #1 Daytime running lights
    Donating Users RayGTP's Avatar
    Michigan
    Has anyone had experience with eliminating their daylight headlight (DRL) function? If so, how did you do it, i.e. wiring change/relay installation.
  2. #2 Re: Daytime running lights
    i know ppl have done it but i dont know how i would like to..ive heard that you just disconnect the drl module but theres two connectors on there and im not sure whitch one to unplug?
  3. #3 Re: Daytime running lights
    Dec 2008
    Lawndale, CA
    On the drivers side dash there is a panel that you can remove. Inside you will see a connector going to a heatsink. Pull that connector off. That disables the DRL's on 97-03's.
  4. #4 Re: Daytime running lights
    is that going to the module?
  5. #5 Re: Daytime running lights
    Michigan
    Quote Originally Posted by The Guz View Post
    Where abouts is the panel, underneath or up top?
  6. #6 Re: Daytime running lights
    Dec 2008
    Lawndale, CA
    Yes.
    On the side of the dash when you open the door.
    This is the heatsink that you should see.
  7. #7 Re: Daytime running lights
    I live here. TLSheff's Avatar
    Searching "disable driving lights" or just "drls" gives so many threads like this it isnt funny... one of them has pictures but i cant find it and after a minute i spent too much time
    http://www.grandprixforums.net/offic...ead-18786.html
    ^^^ is the main thread for this
    Its simple, 97-03 has 2 options
    #1 look on the drivers side at the fuse box, there is a fuse for them, drls or fog lights or something to that effect (my 99 is like that currently, you just have to use the actual switch, they don't come on at night any more)
    #2 is unplug the main module. twilight still works, so the headlights come on at night, open driver door, where the door meets the dash on the side is a plastic panel, give a tug, you should then see the heatsink, just unplug it and voila
    Last edited by TLSheff; 04-08-2011 at 02:41 PM. Reason: Correcting information for #2
  8. #8 Re: Daytime running lights
    Michigan
    You're the bomb Guz. Thanks for the advice. I'll do it as soon as I get home.
  9. #9 Re: Daytime running lights
    Michigan
    #2 is unplug the main module. twilight still works, so the headlights come on at night, open passenger door, where the door meets the dash on the side is a plastic panel, give a tug and open the glove box, you should then see the heatsink, just unplug it and voila
    Excellent! The more info the better. Thanks TLSeff..
  10. #10 Re: Daytime running lights
    newer cars dont like the DRL fuse being pulled.
    they make an awful noise till you put the fuse back in.
  11. #11 Re: Daytime running lights
    http://www.grandprixforums.net/drl-d...ail-25979.html
    Nawarkk found the original section with pics from the good thread... check into it
  12. #12 Re: Daytime running lights
    ok i got it done and now i have my highs with my fogs..but that stupid little connector was the hardest little sob ive ever tried to unplug, in the 02's the switch isnt stright up or to the side its at a angle and its so tight theres no room to work in
    but i did it and now im happy and now i can order my hids
  13. #13 Re: Daytime running lights
    Dec 2008
    Lawndale, CA
    You are right. I believe this is true for 00-03's. It's best to just unplug the DRL diode in the drivers side compartment. As stated, unplugging the connector will still keep the auto headlight feature. If you want to disable the auto headlight feature then do what is written in this link.
    Headlamp Control
  14. #14 Re: Daytime running lights
    Jul 2010
    Coquitlam,BC,Canada
    Headlamp Control
    And if that doesn't work (didn't for me), you can do this.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: Daytime running lights
    Michigan
    I have a 2003 GTP and confirmed pulling the DRL fuse is not the way to go. I heard a relay chattering on the driver side of my dash. However, unplugging the DRL diod did the trick to eliminate my day time lights. The auto twilight function works as it did before.
    I considered pursuing full manual function but not sure if I want to delve that deep.
  16. #16 Re: Daytime running lights
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by RayGTP View Post
    It is really easy. You just have to put a switch on the blue wire of the plug that you removed.
    Here's how I did mine, and of course Back 'n Black's original.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Daytime running lights
    SE Level Member ReapeRx's Avatar
    Jul 2012
    Nebraska
    quick question! I have an 02 and i have aftermarket housings for it and before i get hids for it i need to disable the drls! I want my halos and parking lights to come on just not my low beams! If you guys have some awsners please help!
  18. #18 Re: Daytime running lights
    GTX Level Member blackflag's Avatar
    Virginia
    Mines an 01 and has no drl's. Came like that.
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    Subscribed so I can put in a switch thanks bronco boy. Gonna attempt when I get back home
    Sent from my iPad using Tapatalk HD in this stupid country Afcrapistan...
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  1. 02 GTP Daytime Running Lights
    By techweenie in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2010, 06:39 AM
  2. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  3. A/C and Daytime running lights
    By hydrashok158 in forum General Tech Discussion
    Last Post: 08-14-2009, 09:06 AM
  4. How to disable daytime running lights.
    By ChvyTrcksFrdScks in forum How To Write-Ups/Tech Tips
    Last Post: 05-09-2009, 04:15 PM
  5. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
