Thread: Do my speakers suck or do I suck?
Results 1 to 11 of 11
  1. #1 Do my speakers suck or do I suck?
    SE Level Member Paranoid's Avatar
    Apr 2012
    Cranford, NJ
    So I bought new Pioneer 3 Way TS-A6964R speakers for my rear deck. Taking out the stock speakers I found 4 clips. What I decided to do was connect 2 of the clips together at the speaker, so I could just clip it back into the existing wires.
    The speakers work, but they sound like a bag of crap. The sound cracked. I brought them back to Best Buy and put the new ones back in, but they sound even worse. It's pretty awful. Any advice? Or am I just screwed?
    I have an aftermarket head unit, the Pioneer DEH-P5000, and have only had small problems. It shuts off from time to time, and before I replaced the bad ballast, it would shut off whenever I turned on my HID's.
    If at first you don't succeed, skydiving isn't for you.
  2. #2 Re: Do my speakers suck or do I suck?
    Indianapolis
    How experienced are you in hooking up speakers? did you have the best buy people put the other ones in? I've never been a fan of Pioneer, they all sound harsh and unbalanced IMO
  3. #3 Re: Do my speakers suck or do I suck?
    Out West
    You.
    Whine with your Cheese?
  4. #4 Re: Do my speakers suck or do I suck?
    GTP Level Member simbah's Avatar
    Lala land
    Are you sure that you have the wires phased correctly, positive to positive and negative to negative
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  5. #5 Re: Do my speakers suck or do I suck?
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Do you have an AMP? Is it tuned correctly? check your wires, hooking up speakers isnt rocket science. And if it sounds THAT bad, check your EQ, its prolly all FUBARd
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
    Apr 2012
    Cranford, NJ
    I'm pretty experienced with this stuff, although I haven't seen these plug things before. I was very careful to have them phased correctly.
    It just sounds like a bag of d!ck.
    Sent from my VS910 4G using Tapatalk
    Apr 2012
    Cranford, NJ
    And I do not have an amp, although would like one eventually. I've played with the eq quite a bit with No luck. None of presets sound good and anything I put in doesn't sound good.
  8. #8 Re: Do my speakers suck or do I suck?
    michigan
    Im thinking its your h.u.
    Apr 2012
    Cranford, NJ
    How would I test the hu?
  10. #10 Re: Do my speakers suck or do I suck?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Remove it from the car, get some speakers you know sound fine, hook it up to the rear outputs and play a CD, if it still doesn't sound good then your head unit sucks, if it doesn't sound bad, then you suck. A lot.
    Infinity all around.
  11. #11 Re: Do my speakers suck or do I suck?
    Apr 2012
    Cranford, NJ
    So I tested everything and I figured out it's the hu and likely the mounts for the speakers. So that blows.
  1. Well take a look, And maybe a suck!
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 05-29-2011, 03:06 AM
  2. Tahoes Suck
    By Jakescoots in forum The Rant Forum
    Last Post: 11-19-2010, 11:13 PM
  3. Has to suck to be this guy
    By BADAZGTP in forum Off Topic Discussion
    Last Post: 11-16-2008, 09:16 PM
  4. you all suck
    By chrisgtp in forum Introductions/Noob Questions
    Last Post: 01-04-2008, 08:09 PM
