Thread: new amp much louder
Results 1 to 11 of 11
  1. #1 new amp much louder
    SE Level Member zach_gt's Avatar
    May 2008
    i got a new amp today its a clarion apx1300 300 watt. hooked up to my 2 12 inch sony in a sealed box. that amp hits so much harder than my 800 watt sony. i think i need a new alternator though cause my lights dim pretty badly now
  2. #2 Re: new amp much louder
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i wouldnt say new alternator, you probably just need a capicitor on your battery dude...it holds volts so when your system hits, it pulls from the Cap and doesnt dim your lights.....or you could go alittle more expensive way and get one of those smaller batteries in your trunk...but the Capicitor should do the trick
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #3 Re: new amp much louder
    Apr 2008
    Chillin at the Beach , VA
    That's what I would suggest. Go for the cap. I blew my alt out with a system and lights still dimmed with the new one.
  4. #4 Re: new amp much louder
    May 2008
    yea im gettin one this friday if i have the money its bad enough it shuts my radio off sometimes
  5. #5 Re: new amp much louder
    Apr 2008
    Yea, I hate that. Could never figure out why it does. Only with the aftermarket deck.
  6. #6 Re: new amp much louder
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    I have never had a radio shut off because of amp draw lol. stock ignition with a kicker ZR1000 running 2 ohm stereo on 2 12" kicker CVX's and a ZR600 running at 4 ohms on 2 infinity 6x9's in rear and 2 infinity 4x6's up front. Had that amp turned all the way down lol..Lights dimmed very bad and battery drained to 9 volts all the time but I guess you need to know when to turn it off. Never cared much for class D Amps but I think i'm going to get a kicker ZX 2500.1 and try that one out. I've always been a Kicker fan. But there are many good companies out there I havent tried yet
  7. #7 Re: new amp much louder
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by Hayden View Post
    many good companies i aint tried and never will...just a kicker fan
  8. #8 Re: new amp much louder
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by zach_gt View Post
    maybe just get a new battery...the draw that amps pulling shouldnt make radio shut off
  9. #9 Re: new amp much louder
    Apr 2008
    I don't know what makes it do it. Mine might be different from what he's talking about. Even if I have just my aftermarket deck and no amps, when I open the door sometimes, it'll kill the radio for a split second. Has done it sense day one of having the system. Rewired it and the same thing. I have it going into the factory harness. Haven't tried to wire it up without that. It don't bother me so I just leave it alone.
  10. #10 Re: new amp much louder
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    If you decide to upgrade your alternator look up Dominic Iraggi. He's out of Nashville but his alternators are well known around the audio scene. He can do everything from small upgrade to 20volt adjustable. Iraggi alternators is the name I would google.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  11. #11 Re: new amp much louder
    Saraland Alabama
    that is the difference between an honest company, and one using peak power at 18 volts and at the amp smoking (sony does not rate following the guidelines of the cea clarion and other reputable car audio companies do)
