Thread: 98/04 audio swap?
Results 1 to 7 of 7
  1. #1 98/04 audio swap?
    Michigan
    Awhile back I was a proud owner of a 98 GTP, but sold it and got a newer 04 GTP. I love the 3800's. Anyway, the 04 has the monsoon system in it, but honestly it sounds nowhere near as full as the 98's system. Has anyone done any sort of swap on the 04 system? I guess just having the 8-channel analog EQ would be fantastic, but having the speaker set would be great too.
  2. #2 Re: 98/04 audio swap?
    Sep 2011
    Arkansas
    Why not just go aftermarket?
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #3 Re: 98/04 audio swap?
    GTP Level Member simbah's Avatar
    Lala land
    98 is din and half and 04 is double din so if you could get it to work wiring wise ( I highly doubt it) you would be left with a hole in your dash either under or over the radio.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: 98/04 audio swap?
    Michigan
    Quote Originally Posted by Fatboy501 View Post
    Because I like the sound of the old one. Also, it has an analog EQ. I listen to a very wide variety of music and the digital EQs are a pain to change. I'm not too worried about the hole in the dash, I can make something up to fit there. Been wanting to put in multicolor interior lights; would be a great place to mount switches and pots.
  5. #5 Re: 98/04 audio swap?
    Sep 2011
    Arkansas
    I mean, it's possible... but by time you make it work, you could easily have yourself a pretty nice aftermarket system. Also, who said you have to deal with digital EQ if you go aftermarket? There are plenty of EQs if you prefer knobs/buttons/sliders... from 1/2-din dash units to full-blown trunk-mounted units. Again, can it work? Yes... do I personally think it would be worth the time invested when compared to researching and piecing together an aftermarket system to suit your needs? Absolutely not. I understand liking the sound of it... but I truly believe that you can achieve much better results by utilizing the amazing array or aftermarket car audio products available to us today.
  6. #6 Re: 98/04 audio swap?
    Michigan
    Also, the cars have similar steering wheel controls; I'd like to retain those if possible. Do you know of any aftermarket units with an analog EQ? I haven't seen one anywhere.
  7. #7 Re: 98/04 audio swap?
    you buy a wire harness to keep the steering wheel controls.
  1. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  2. New audio setup! JL Audio
    By GP JLM in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2011, 12:27 AM
  3. 04 GTP Audio Help
    By CJE in forum Audio, Security & Visual Electronics
    Last Post: 05-11-2010, 09:31 PM
  4. Aux Audio
    By iflycessnas05 in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2008, 06:28 PM
