Thread: need some help with 06 gp gxp with monsoon system
Results 1 to 4 of 4
  1. #1 need some help with 06 gp gxp with monsoon system
    Nov 2010
    baltimore,md
    i have and o6 gp gxp with the monsoon system and nav change the door speaker to kenwoods and the rear deck speakers to polk audio 690s
    and know it sound even worst i have since add a 13in rockford sub with amp to mask the horrable sound coming from the other speakers.
    what would i need to do to get better sound ? a local high in radio shop told me that i need to get a new hu or add a sound processor.
    my question is what make a monsoon system the hu or the stock amp? what signals or coming from the hu to the amp. could i just bypass the monsoon amp
    all together and wire the hu to a 4 channel amp or something? i what all speakers working right doors center and rear deck. please can i get some help varloc01@gmail.com
  2. #2 Re: need some help with 06 gp gxp with monsoon system
    GTP Level Member simbah's Avatar
    Lala land
    Replace the pathetic Monsoon amp with a high quality aftermarket amp and run all new wires.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: need some help with 06 gp gxp with monsoon system
    Nov 2010
    baltimore,md
    Quote Originally Posted by simbah View Post
    so you are telling me that all i have to do replace the amp and run new speaker wires and i still will be able to use the stock hu with no problem and still have function of on star.
  4. #4 Re: need some help with 06 gp gxp with monsoon system
    Lala land
    Yes and don't forget the line out converter to convert high level speaker inputs to low level, or an amp with high level speaker inputs and then wire from speaker inputs going into Monsoon amp,going to have to do a little research but I think it will be better in the long run, you always replace you HU with aftermarket too and just get the proper harness or harness' to maintain Onstar and steering wheel controls
  1. how do i tell if i have the monsoon system?
    By 98grannyprix in forum Audio, Security & Visual Electronics
    Last Post: 02-16-2012, 02:36 PM
  2. 2008 GP with Monsoon System
    By mjs2011 in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2011, 02:10 PM
  3. help with monsoon system
    By chrisp847 in forum Audio, Security & Visual Electronics
    Last Post: 02-11-2009, 02:19 PM
  4. Need help with Monsoon sound system please
    By Keith04gp in forum General Tech Discussion
    Last Post: 09-29-2008, 04:51 PM
