Thread: Custom Subwoofer Enclosure
Results 1 to 13 of 13
  1. #1 Custom Subwoofer Enclosure
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    Hey guys, as some of you know i just finished installing a new head unit along with dual 12" sub woofers. I got the subs for free from a friend and each came with its own single box. i am wanting to build a custom fit box for both subs to make it look nicer. has anyone done this and have some specs?
    also the subs i have now say that the optimum volume is 1.5 cubic feet, but at some point i plan on probably replacing them, i was looking at the subs probably in the price range i would be and 95% of them say 1.25 cubic feet, should i make the box at 1.25 to plan for the future? or should i make it 1.5 for now and make a new box when the time comes? or would using the old box with new ones be that bad?
  2. #2 Re: Custom Subwoofer Enclosure
    Mar 2012
    NC
    Make the box 1.25 and use poly fill to slow down the sound waves and create the illusion of using a bigger box.
  3. #3 Re: Custom Subwoofer Enclosure
    Houston
    Quote Originally Posted by hitman92499 View Post
    Exactly what I was going to say.
  4. #4 Re: Custom Subwoofer Enclosure
    Nov 2011
    Decatur
    would I then remove the polyfill when I upgrade?? I also read car audio polyfill is really expensive but you can go to walmarts craft section and get it real cheap and they're the same thing is this true?
  5. #5 Re: Custom Subwoofer Enclosure
    Mar 2012
    NC
    Yup. Otherwise the enclosure would be "too big." And yes the Walmart stuff is the same. Just less expensive.
  6. #6 Re: Custom Subwoofer Enclosure
    Houston
    Or you can rip open the arm rest on your couch and gut it....freebie!
  7. #7 Re: Custom Subwoofer Enclosure
    wuuuuuuuuuuuuuut.
    poly makes the enclosure seem larger.
    not smaller.
  8. #8 Re: Custom Subwoofer Enclosure
    Mar 2012
    NC
    I think you missed that part Matt. LOL
  9. #9 Re: Custom Subwoofer Enclosure
    Nov 2011
    Decatur
    how much polly fill should i use?
  10. #10 Re: Custom Subwoofer Enclosure
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    just fill up the box, not to much so it gets in the sub.
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  11. #11 Re: Custom Subwoofer Enclosure
    Florida
    I personally would build separate boxes... especially since you have not decided on what subs your upgrading to. As far as polyfill goes i have used the stuff in a truck build we did and it does work. However you should do your research on it before just throwing it in because you can over stuff... here is a link that should help if you decide to go the poly-fill route, GlassWolf's Pages.
  12. #12 Re: Custom Subwoofer Enclosure
    GTP Level Member
    springfield IL
    1 lb per cuft..... Also make sure u pull it apart b4 putting into the box. Baseball or softball size chunks is good.
  13. #13 Re: Custom Subwoofer Enclosure
    Nov 2011
    Decatur
    if anything ill understuff pollyfill to be on the safe side of things...
  1. A little project I've been working on, Sub Enclosure, HUMount (Installed Pics)
    By BlownBigBlock in forum Audio, Security & Visual Electronics
    Last Post: 04-05-2012, 09:38 AM
  2. Subwoofer help....
    By Jordin in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2011, 10:56 PM
