Thread: Hid questions
Results 1 to 7 of 7
  1. #1 Hid questions
    Apr 2012
    Michigan
    Hey fellas im new, just got the ddm tuning conv kit 35w 6000k, my question is, do i need to pull the drl diode? And where exactly is it (i've read that it's located in the driver side panel) but i still can't find it.
    Is it safe to use electrical grease on the connections?
    Also have any of you installed interior leds? How do you like it and where can i find them for a decent price?
    Any known problems that i will encounter? Any help or tips are appreciated
  2. #2 Re: Hid questions
    vender on there sells leds interior, i have bought them and many others have to
    yes you need to pull the diode thing, its got head sink around it and its right inside the panel on the drivers side of the dash theres only one connector you can see and thats the one you need to pull
    there really stright forward, plug and play
    just post in here with any problems you may have
    SMGPFC Member #10
  3. #3 Re: Hid questions
    Apr 2012
    Michigan
    I don't see it i've looked for it and looked for it i dont see it i may be overlooking it. All i see is a black plastic box with two harnesses connected to it
  4. #4 Re: Hid questions
    wait do you have an 04+?
    if so im not 100% sure on those were it is, i was thinking of 97-03's
    sorry, i guess i should have read you name before hand
    SMGPFC Member #10
  5. #5 Re: Hid questions
    Apr 2009
    Fort Worth TX
    I think in some of the newer GM cars the DRL module may be located in or near the under hood fuse box. Let us know if you find it.
  6. #6 Re: Hid questions
    Apr 2012
    Michigan
    Quote Originally Posted by Rico View Post
    Yea i couldn't find it so i'm just going to leave it until i find an alternative.
  7. #7 Re: Hid questions
    Apr 2012
    Michigan
    Yea its an 04 i thought it was in the driver door compartment until i actually looked. I should have done more research first.
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. A few GXP questions
    By black954 in forum General Tech Discussion
    Last Post: 11-16-2011, 12:05 AM
  3. few questions
    By PMave in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 10:51 AM
  4. new guy many questions
    By 1bad05gto in forum Introductions/Noob Questions
    Last Post: 04-07-2010, 01:13 PM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
