Thread: Anyone else have this happen?
Results 1 to 18 of 18
  1. #1 Anyone else have this happen?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    I have two 12 inch Polk Audio subs, along with a 1600 watt amp.
    I was curious if other people have this happen, when the bass hits hard on the sub woofer, for example when the volume is maybe 1/2 on the head unit, my inside dome lights dim almost all the way down, and my head lights dim a lot also.
    Time for a new alternator?
    what do you think?
  2. #2 Re: Anyone else have this happen?
    Please post up what brand and how you ran your power wiring. What you hooked it up to, all the parts in the system, including the rca's, head unit, how you tooked to power and ground.
  3. #3 Re: Anyone else have this happen?
    Portland Oregon
    Sounds like you need a big capacitor or an extra battery in the mix
  4. #4 Re: Anyone else have this happen?
    Mar 2012
    Minneapolis MN
    Head unit: Sony CDX GT34W - radio / CD / MP3 player - In-dash car stereos - CNET Archive
    Amp: PowerBass Autosound ASA 600.4x 4-Channel A/B Amplifier | PowerBass USA
    Subs: db212-2 Car Subwoofer from Polk Audio
    The power is hooked up to the fuse relay. On the left side of the car is the power, remote, and ground. The right side is the rca cord.
    Wired with a Kicker amp kit.
    The ground is hooked up to a bare metal part under the rear seat.
  5. #5 Re: Anyone else have this happen?
    Kicker kit.. got a link or any specs?
  6. #6 Re: Anyone else have this happen?
    Portland Oregon
    Move the power to the battery and get an alt rewire for the underwood relay center. Should help a tad. You'll still need a cap or extra battery I think though
  7. #7 Re: Anyone else have this happen?
    Mar 2012
    Minneapolis MN
    Kicker - D-Series Amplifier Installation Kit - 09DPK4 theres the kit. i had to get the kicker rca seperate - Kicker - Z-Series 9.9' 2-Channel RCA Audio Cable - 09ZI23
    And i have a new 80amp inline fuse. (i broke the one that came with it...
    And what do you mean Alt rewire?
  8. #8 Re: Anyone else have this happen?
    Mar 2012
    NC
    Upgrade the stock 8 gauge alternator wire to a 4 gauge. It'll help dramatically.
  9. #9 Re: Anyone else have this happen?
    Mar 2012
    Minneapolis MN
    that's the one from the battery to the fuse relay right?
  10. #10 Re: Anyone else have this happen?
    Portland Oregon
  11. #11 Re: Anyone else have this happen?
    Mar 2012
    Minneapolis MN
    well that's certainly a cheap enough place to start i will check it out and keep updated
  12. #12 Re: Anyone else have this happen?
    Mar 2012
    NC
    Basically get a piece of 4 gauge wiring about 24-30 inches long. Wire it to the alternator output terminal and to the positive battery post. The factory 8 gauge wire for the alternator will stay in place. The factory wire runs half way around the damn car and is too small to power the car, let alone subs.
  13. #13 Re: Anyone else have this happen?
    Yes, but leave the original on as well.
    The kicker kit doesn't say anything about the wire or it's quality. I used Knu for mine and attribute that to a lot of the lack of issues that I have. I have zero dimming etc. But then we have different setups. Take a look at this basic Knu kit. 4 Gauge Amplifier Installation Kit Tells you what the wire consists of. How it's connected etc.
  14. #14 Re: Anyone else have this happen?
    Mar 2012
    NC
    If I try to dim my lights after doing this upgrade I can, but typically I don't turn mine up that loud. Getting too old for that I guess. LOL
  15. #15 Re: Anyone else have this happen?
    Mar 2012
    Minneapolis MN
    cool i will start with an alt rewire and then if that doesnt solve everthing i will move on to rewiring.
  16. #16 Re: Anyone else have this happen?
    Another idea would be an alt with more power.
  17. #17 Re: Anyone else have this happen?
    Mar 2012
    NC
    Run more wire to the amp first.
    One four gauge run isnt enough from my limited experience.
    That amp might draw over 1.6 kW, which is quite a bit for a single run of 4.
  1. what would happen?
    By str3etgl0w in forum General Tech Discussion
    Last Post: 06-29-2011, 08:13 PM
  2. What would happen if??
    By fratzke7 in forum General Tech Discussion
    Last Post: 04-30-2009, 11:05 PM
  3. Gen 5 S/C to Gen 3 I/C- What needs to happen?
    By TDCRacing in forum General Tech Discussion
    Last Post: 01-11-2009, 07:48 PM
  4. when did it happen?
    By UR LOSN in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 01:39 AM
