Thread: Monsoon Rear Speaker upgrade and wiring??
Results 1 to 6 of 6
fredfree Monsoon Rear Speaker upgrade... 03-04-2012, 12:22 AM
KeithGTP03 Re: Monsoon Rear Speaker... 03-04-2012, 12:44 AM
fredfree Re: Monsoon Rear Speaker... 03-04-2012, 01:06 AM
KeithGTP03 Re: Monsoon Rear Speaker... 03-04-2012, 01:28 AM
fredfree Re: Monsoon Rear Speaker... 03-04-2012, 02:54 PM
fredfree Re: Monsoon Rear Speaker... 03-10-2012, 06:56 PM
  1. #1 Monsoon Rear Speaker upgrade and wiring??
    Moorhead, MN
    Quick question- looking to upgrade the rear 6x9s in my 05 gp with monsoon, searched some and it sounds like a component system would be best for replacement? Would the wiring for a component system be, to use the low output for the woofer/midbass and the high for the tweeter? a crossover wouldnt be needed since the monsoon amp is doing what the crossover would? right?? Not sure? Thanks
  2. #2 Re: Monsoon Rear Speaker upgrade and wiring??
    Houston
    No you wont need the crossover. But I believe the monsoon speakers are 2 ohm. So you'll want to find a 2 ohm 6x9 component speaker, or you'll be disappointed in your new speakers.
  3. #3 Re: Monsoon Rear Speaker upgrade and wiring??
    Moorhead, MN
    Thanks for the reply, i thought i remembered in a different post about the monsoon speakers being 4 ohm? ill have to do so more searching. also was thinking aobut going with a 6.5 round speaker in the rear since that was what crutchfield kind of suggested? thanks agian
  4. #4 Re: Monsoon Rear Speaker upgrade and wiring??
    Houston
    Yeah, the 6.5's will work just fine....you'll just need to buy or make adapters. I'm pretty sure they're 2ohm...but you can test that easily with a DMM. I believe the 6x9's are run off the amp, and the tweets are run off the deck
  5. #5 Re: Monsoon Rear Speaker upgrade and wiring??
    Moorhead, MN
    Will do, thanks
  6. #6 Re: Monsoon Rear Speaker upgrade and wiring??
    Moorhead, MN
    Speakers measured out at 4 ohm, thanks
  1. Wiring for rear deck speaker replacement (with Monsoon)
    By Infinity9999 in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2013, 07:49 PM
  2. Monsoon System - What ohm speaker do I need for the center dash speaker?
    By Schmitty in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 07:01 AM
  3. Speaker install on an 04 GT-P (non monsoon)
    By kurukato in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2011, 11:00 PM
  4. Help on rear speaker wiring
    By 06PONTGP in forum Audio, Security & Visual Electronics
    Last Post: 06-03-2011, 09:56 AM
  5. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
