So i installed my new HU 2 nights ago (VM9224bt) and last night i started running the wiring for my amp (KX600.1) which will be mounted in the trunk. Problem being that the route i was going to use for my power wire is longer than the wire itself.
So i am looking for some ideas on where everyone has run their wires or if there is somewhere else i can mount my amp.
Also where has everyone run the ground wire for their amps?
