Thread: Hippo's Audio Build Help
Page 1 of 22 12311 ... LastLast
Results 1 to 20 of 422
  1. #1 Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Ok, I'm switchin' up all the audio on my car and want to hear some opinions and recommendations. I just want a build with high quality sound and a little bass when I want it. Here is what I've got picked out so far:
    Morel Maximo 5.25" Component Set Amazon.com: Morel Maximo 5.25-Inch Component Speaker System: Car Electronics
    Morel Maximo 6x9" Set Amazon.com: Morel Maximo 69C 6x9-Inch Coaxial Speakers: Car Electronics
    Kenwood KDC-X996 HU Kenwood KDC-X996 Bluetooth/Pandora/HD/Sirius XM CD Receiver | Pacific Stereo
    Powerbass XAX-4160FD Amp eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    Let me know what you think about this and if you have any suggestions. Also will I need to buy any wiring? Should I have this stuff professionally installed? Thanks.
    iLoveSpade
  2. #2 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    If you're asking questions like that, yes, you need a pro install.
    Also. Forgot 6x9s, they don't do anything at all. Just drop in some 8" subwoofers, then you got your bass in the back and your mids and highs up front.
  3. #3 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    I wasn't really planning on subs. Is there anything I can do about the 6x9's?
    iLoveSpade
  4. #4 Re: Hippo's Audio Build Help
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Quote Originally Posted by Hippo Machine View Post
    You should plan on subs, you will never want to go back to a car without subs once you have heard one with them. Im sure you can find a fairly cheap sub(s) on your local classifieds. I got 2 10's with a 400 watt amp for 120$ and thats more bass then id ever want.
  5. #5 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    Rear speakers are just awful that's all. They don't change/add anything significant, especially once you have nice front mids and highs. And that's why I'm saying 8 inch subs. You widen the holes where the 6x9s were, drop in some 8 inch subs, you have your bass. You'll never truly have "a little bass" with just coax speakers. With that, run a stereo 2/4 channel amp for the front speakers and a mono d-class amp for the rears 8" subs. With a d class you'll be able to just drop it underneath the rear seat, and if you want to get fancy, you can drop the stereo amp under the center console. Totally hidden, totally upgraded sound.
  6. #6 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Ok I will consider^^
    So drop in subs, not in trunk really?
    iLoveSpade
  7. #7 Re: Hippo's Audio Build Help
    GTP Level Member
    Nov 2011
    Kansas
    I noticed a huge difference going from stock 6x9s to my JL's.
    IMO, the GP is too big to run a "front stage" unless you never have passengars.
  8. #8 Re: Hippo's Audio Build Help
    May 2011
    Does anyone think I will even notice a difference with the new 6x9's?
    You'll notice more of a differnce just hooking up a new HU. But you will notice a bit clearer sound and maybe a bit more bass just by putting the 6x9's in.
  9. #9 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    People run 8"s in the rear deck all the time. That's the substitute for actually dropping a sub box in. It's going to give you an honest bit of bass that 6x9s wont give you. The coax in the front are already going to be giving you your mids and highs. If I was doing a build like this, that's how I'd do it. But i'm not. Instead I have 4 12"s and simply unplugged my rear speakers. Just to tickle my fancy, while they were still plugged in, I faded the music all the way to the front, heard almost no change. Faded all the way to the back, tons of change.
    Like cameron said up there a "bit" as in, not enough to be worth it. You'll get REAL bass by running 8s, and REAL everything by running 8s combined with some quality mids and highs.
  10. #10 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    What I was thinking is get what I have listed above, and maybe get a 10" sub or similar, eventually.
    iLoveSpade
  11. #11 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Sean do you know anything about modifying the stock front brackets to fit 6.5" speakers? Cuz the morels have the same set in 6.5" as well.
    iLoveSpade
  12. #12 Re: Hippo's Audio Build Help
    you can put 8's on the rear deck in place of the 6x9's?
    SMGPFC Member #10
  13. #13 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    Yeah. Just cut it up, and fab up your own bracket if needed.
    Just pick a good open-air sub.
  14. #14 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    bahhh idk!!
    iLoveSpade
  15. #15 Re: Hippo's Audio Build Help
    Feb 2009
    Virginia
    The 8's will add more rattle but that's only because they'll play lower. DLS makes some IB 8's that are decent. Otherwise, just grab some Type R 8's and give them .5 cubic feet
    11 is louder than 10!
  16. #16 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    Quote Originally Posted by I800C0LLECT View Post
    So I should go with 8's instead?
    What do you mean by .5 cubic feet..
    iLoveSpade
  17. #17 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    He's talking about a box. A box that, once the subs are mounted, still have .5 cu^3 of volume inside.
  18. #18 Re: Hippo's Audio Build Help
    Jun 2011
    Detroit, MI
    So if i want 8" in the rear, i still need a box? If so, then I'm going with the 6x9's and will get probably like a single sub later.
    iLoveSpade
  19. #19 Re: Hippo's Audio Build Help
    Nov 2008
    Waterloo, Iowa
    No. You don't get it. At all.
    He said if you want to put them in the rear deck, aka, infinitely baffled setup, get these:
    DLS OA8 (OA-8) 8" Single 8 ohm Performance OA Car Subwoofer
    Otherwise, get Type R's and put them in a box.
    Honestly, if you dont get any subs at ALL don't waste your money on 6x9s....
  20. #20 Re: Hippo's Audio Build Help
    indiana
    Why is everything ripping into 6x9s. How do none of you notice a huge difference with them? If you want a little bass get a small sub and small amp. Replacing all the stock speakers will make a ton of difference even if you only run them off the head unit but for even better sound quality get a 4 channel amp for them
  1. Hippo, take notes
    By EJOUIE in forum Off Topic Discussion
    Last Post: 11-11-2011, 09:13 PM
  2. Blackbonnie's 05 GP GT audio build log
    By blackbonnie in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2009, 12:40 AM
  3. well I am starting a new audio build. This time it is sq.
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2008, 06:08 PM
