I honestly don't know how to do that...
there were a few write ups on it. Once you do it, you'll realize how easy it is.
but if you dont want the hassle just put in some decent 5.25's and amp them. There's really not a big difference between 5.25's and 6.5's
Check this thread out for a little more info
http://www.grandprixforums.net/help-install-60102.html
Ok I ordered the morel 5.25 coaxial speakers (not component set). They should be here this week.
I HAZ QUESTION: When installing the new speakers, what should I do with the factory tweeters? Should I unplug them or just leave em plugged in or buy some new ones?
Opinions are appreciated.
You lost me at morel 5.25 coaxial speakers.
Lol Morel Maximo 5.25" front speakers (2-way)
ok, so unplugging the front tweeters is the way to go i guess.
Why would you unplug your highs?
the factory tweeter would have been connected to the factor mid woofer, so the new coaxial replaces them both
Coax fails!
Edit:
HIPPO FAILS!
So what do you think I should do?
Ok, I'm stock powered for right now. Amplification in the future. Thanks.
BUT do you think it will sound better with or without the tweeters? I'm not sure if they are blown out or not.
If you can't hear them rattle, they're not blown. Simple as that. :P
It'll sound better with them...
Ok the Morels are in and sound great! I ended up leaving the tweeters unplugged. I think I will replace the tweeters with some 6 ohm 1" replacements eventually. (the stock ones are 1" right?)
Dynamat was not installed... too complicated with how our speakers are mounted. (Wheres an easy place you think I should put it? I have two 10"x10" sheets)
There was some aftermarket wiring going on in the doors, just to the 5.25's. Kinda interesting.
ALSO it sounds like one of my Kenwood 4" 3-way speakers may be rattling already. I will keep an eye on it. Otherwise coming along nicely!
if u think those kenwoods are rattling, might as well put the dynamat there
Would it be good to put it underneath the rear deck in the trunck
Honestly....seal the doors with dynamat/sound deadener/second skin/raamat...whatever product you choose. Next, don't use the stock tweeter and see if you like it, then use the stock tweeter and see if you like it. I have a feeling it might sound better without it. Once you seal up those doors, put a layer of ensolite between the door skin and panel. When replacing the mid...make a pancake out of duct seal right behind it making sure to put as many non symetrical shapes as you can on the surface.
