Thread: cruise control works but no indicator light?
Results 1 to 7 of 7
genki cruise control works but no... 08-19-2013, 12:13 AM
Fivefingerdeathpunch Re: cruise control works but... 08-19-2013, 12:19 AM
dsmuts Re: cruise control works but... 08-19-2013, 05:55 AM
genki Re: cruise control works but... 08-19-2013, 11:13 AM
dsmuts Re: cruise control works but... 08-19-2013, 02:56 PM
genki Re: cruise control works but... 08-19-2013, 03:14 PM
stealthee Re: cruise control works but... 08-19-2013, 05:55 PM
  1. #1 cruise control works but no indicator light?
    Donating Users
    Aug 2013
    Michigan, USA
    The manual stated there should be a lighted icon on the cluster when the cruise control is set. When I set it, I don't see it at all. When I turn the car on and all of the test light comes up, the cruise control light also does not light up. Either it's burned out or my car doesn't have it at all.
    Wondering how can I get there to check if it is a burned out indicator bulb? The whole dash seems to be put together with lots of snap connector or hidden fastener and I don't want to break the dash just to check one bulb. A how-to guide on removing the panel would be good.
    TIA!!
  2. #2 Re: cruise control works but no indicator light?
    My 2000 grand prix has no light on the dash for this because they didnt come with it.
    Not sure if 04+ is different.
  3. #3 Re: cruise control works but no indicator light?
    04+ says it in the dic
  4. #4 Re: cruise control works but no indicator light?
    Donating Users
    Aug 2013
    Michigan, USA
    Hmmm will need to watch the DIC. Still not used to having separate LCD for information.
  5. #5 Re: cruise control works but no indicator light?
    so you have an 04+? You never did say what you are driving.
  6. #6 Re: cruise control works but no indicator light?
    Donating Users
    Aug 2013
    Michigan, USA
    Oops, 05 so yeah 04+
    cruise indicator does come up on DIC. The manual I was reading didn't make that clear and seemed to imply the icon comes on the cluster with other icons and not on DIC only.
    This is solved. Still not used to having separate DIC
  7. #7 Re: cruise control works but no indicator light?
    SWPA
    My 07 has a green light on the speedometer that is lit when the cruise is on.
  1. Cruise Control Light?
    By Chaparral in forum General Tech Discussion
    Last Post: 12-11-2012, 08:06 AM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:19 PM
  3. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum General Tech Discussion
    Last Post: 07-30-2012, 07:16 AM
  4. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 07:14 AM
  5. Cruise control randomly works
    By mach158 in forum General Tech Discussion
    Last Post: 08-25-2010, 08:39 PM
