Thread: weird question
Results 1 to 9 of 9
  1. #1 weird question
    GT Level Member nicks98gtp's Avatar
    michigan
    so i bought a spare DIC for my 98 gtp, so i could try and convert it to blue leds, like ther est of my interior lights. the spare i found was out of a 99 gt, which i heard would work but wouldnt show boost, etc. well i got it plugged in, and it does show boost, everything functions as it should, Perf. shift is located there now instead of my gauge cluster as well. The only thing i noticed is when the cars started, the "Trac off" light is illuminated but the TC system is on. When i push the button the light goes out, but TC is shut off. its like the TCS Off button is reversed. anyone got any ideas?
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
    Ohio
    Generally, you don't mix match gtp and gt dics. 98-03 is fine to use, 97 is different
    Sent from my DROIDX using Tapatalk
  3. #3 Re: weird question
    michigan
    only reason i bought it originally was to try the blue leds in it, that way if i screwed it up i wouldnt ruin mine, but when i hooked it up n it showed boost, and moved my perf. shift to it, i kept it. If the only downfall is my tcs off light being on then so be it i guess lol
    Ohio
    If it works then go for it
  5. #5 Re: weird question
    Charles City, IA
    Moved, not really a question about brakes.
    SMGPFC Two Nipple General
  6. #6 Re: weird question
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    Read somewhere that the way the GTP and GTs traction works, that the modules read it differently.
  7. #7 Re: weird question
    Houston
    Remove the Trac off bulb.
  8. #8 Re: weird question
    Yoga city
    why dont you just do the mod on the original, seriously an infant with some knwoledge could do it. not being mean but it really isnt all that complicated
  9. #9 Re: weird question
    michigan
    in the process of it, main reason i kept this one is because it has "performance shift" located on it rather that on my gauge cluster which i prefer.
  1. thats weird?!......
    By twol8uluz in forum General Tech Discussion
    Last Post: 06-04-2011, 11:08 PM
  2. weird DTC...
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-17-2010, 12:33 AM
  3. weird....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-24-2010, 12:30 AM
  4. weird GTP
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2010, 09:51 PM
  5. weird...
    Last Post: 10-15-2008, 10:56 PM
