Thread: Looking into an Anti-Auto Theft device....any suggetions?????
Results 1 to 12 of 12
  1. #1 Looking into an Anti-Auto Theft device....any suggetions?????
    SE Level Member rell2005's Avatar
    Detroit / Grand Rapids
    Ok guys,
    I'm from a pretty rough area in the city of Detroit and after my college graduation, i'll be moving back to Detroit. If anyone if familiar with the city, its 7 mile and Greenfield. I really want to look into some anti-theft devices because in my area, auto theft and car-jacking are a BIG problem, and I have a 4 year old daughter to protect. So any suggestions on where to look? or what to consider? I know my buddy has a switch for his cop-car that turns on his fuel pump, and it won't even turn over without it. So I thought that was cool. But any ideas? Thanks for reading.
  2. #2 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    Omaha, NE
    The most expensive 2 way viper you can get!
    They have vibration sensors, 2 way remotes, tilt sensors, shock sensors, glass sensors. all sorts of add ons.
  3. #3 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    SE Level Member rodneypierce's Avatar
    Jan 2012
    Cedar rapids, IA
    a 12 gauge..
  4. #4 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    have you tried using rust?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    Houston
    The easiest and cheapest way is to cut the starter wire, wire up a switch and hide the switch. When you get out of the car flip the switch off and the starter is dead. This will prevent theft by amateur car thieves, but will only slow down more advanced thieves. Or you can get a digital starter kill. They come with a keypad that requires a code before the car will start. It will also require a code within 2 minutes or so, if the door is opened while the car is running. So if you are car jacked, they will not get too far before the car dies. And they're not very expensive. 103T Digital Failsafe Starter Kill
  6. #6 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    GTP Level Member
    Nov 2011
    Kansas
    I have the Viper 5901 which is awesome. I have only added the additional shock sensor and it is great. But like Brian said, this thing can do it all. I would get the 5901 not the 5902. I have heard complaints of the buttons getting hit accidentaly on the 02 remote. And with the range of this thing, you dont want to unlock it not meaning to in your pocket.
  7. #7 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    Houston
    I agree with the 5901. I have that also and there are a ton of things you can add to it. But, if your car is not a daily driver, I wouldnt recommend it. I had to remove mine because I got tired of the car battery being dead. But if your car is your daily, and you want to spend a few hundred bucks, I would go that route.
  8. #8 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by rell2005 View Post
    Ok guys,
    After college grad you are moving back ? move
    1997 Red GTP 182000 miles stock
  9. #9 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    It really depends on how you want to do it.
    Fuel: interupt the ground to the fuel pump
    Interupt the injector power
    Starting: interupt the p/n signal to the PNP switch
    I can see pro's and cons to all the above.
  10. #10 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    Quote Originally Posted by GTP in RTP View Post
    Believe me if I had the means I would, but its not that simple
  11. #11 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    SE Level Member 2DeepInc's Avatar
    Sep 2011
    Fayetteville,NC
    check out Clifford BlackJax works with any alarm.
  12. #12 Re: Looking into an Anti-Auto Theft device....any suggetions?????
    GTP Level Member joshv's Avatar
    canada
    trunk monkey Trunk Monkey : get rid of thieves - YouTube but in all seriousness viper is a good route
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  1. Anti-Theft/Remote start for 2002 GP GT coupe
    By Dzebold in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2011, 10:11 AM
  2. Replacing Anti-theft system
    By mvp2765 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 09:03 PM
  3. 1997 grand prix anti-theft system components
    By Konstantin in forum Audio, Security & Visual Electronics
    Last Post: 10-10-2010, 03:36 PM
  4. Where to buy new keyless entry device?
    By doug331 in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2009, 01:22 AM
  5. Suspension Limiting Device
    By jmak gtx2 in forum Brakes/Suspension/Chassis
    Last Post: 06-01-2008, 11:42 PM
