Thread: Putting in a switch for subwoofers
Results 41 to 60 of 78
  1. #41 Re: Putting in a switch for subwoofers
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    Either way I posted about opinions on a switch do that I'm not blasting subs with people in the car, but the info chamoltongave is useful, I'm not worried about draining as much, I just wanna put the cap in, I've seen it installed, I can get one cheap that works great so it's worth the little money I'm spending on it, and now I'll have it in case I upgrade to a higher output than what I'm planning which as of now is two ten inch subs with a max watts at 1000 and an amp with a max watts at 760. Whether or not that's a high enough output for a cap I dunno, I'm not an electrician but I gather basic install easily. So thank u all for the input on the cap but I got what I asked for which is info on the switch which if the info I've gotten is correct goes in the remote connect wire.
    2002 Pontiac Grand Prix SE --> Audio, Lighting, Exterior
  2. #42 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    OP... Fine, go ahead and install a cap! H e l l put 5in for all i/we care.... Lol. Your wasting your time and elctrical. Just adding xtra strain on the electrical system.
    again... Go to caraudio.com. Become a member, ask why you should or shouldnt use a cap. Dont be surprised if you get BLASTED! And not to mention this "switch" thing..??!! Hahaahhaaahaha
    Drugs are bad mmk!
  3. #43 Re: Putting in a switch for subwoofers
    Jun 2011
    ontario
    the switch is a great idea. i have used mine many many times. costs like nothing and for peace of mind its great.
  4. #44 Re: Putting in a switch for subwoofers
    Pennsylvania
    Quote Originally Posted by SINister View Post
    ...seriously? I'm still trying to figure out why someone would want to remove some desirable frequencies from their listening experience. I mean, I guess if you had a kid with some kind of medical problem prohibiting it, and you just have to listen to music when you chauffeur him... Maybe I'm not as imaginative as I used to be.
  5. #45 Re: Putting in a switch for subwoofers
    Nanuet, NY
    Well guess what, i do have hearing aids, I am partially deaf, after a while in my friends car with subs it gets to be a lil too much, not to mention I drive lots of people around not all of them young, they don't all appreciate loud subs, and yes it's also added peace of mind
  6. #46 Re: Putting in a switch for subwoofers
    Pennsylvania
    Quote Originally Posted by EJRJR91 View Post
    Health-related. Solid reason. I'm guessing your aids are too sensitive to the lower frequencies, then?
    Turn the volume down then - the rest of the frequencies are too loud, too.
  7. #47 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    Op... You dont need subs then. A single 8 or 10 along with good components will sound GREAT! Make sure u have or know some one is has SQ experiance. That part is KEY for a well tuened and great sound set up.... I know a sq guy that has a set of comps up from with a single 10... Prolly one of the best cars i HAVE EVER EVER HEARD!!! He also use to be in SQ comps. He knows his shiit! Lol. Still think the switch is a bad idea and i already know the cap is a STUPID idea.... :-).
  8. #48 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    Op they also make decks with sub levels that can be adjust... Im simpler terms..a sub volume switch!
  9. #49 Re: Putting in a switch for subwoofers
    Nanuet, NY
    Watever I got the info I asked for which is where the switch would go if it goes in. Ima just do what I planned on doing, why should I do different just bc ur preference is different. I have never seen nething I plan on doing damage a car, so I see no reason not to do it. I just prefer two subs to one, something about balance to me, on on either side of the trunk with individual boxes so I can sell one if I so choose eventually. And I picked the 10s bc they're shallow mounts nd I couldn't find many 8 shallow mounts with good reviews, and 12s too big so
  10. #50 Re: Putting in a switch for subwoofers
    Jun 2011
    ontario
    i put my switch in for wen i am sitting waiting for people and i dont want to run my car but i still want music if i gonna sit for a while i will turn down the volume and just switch off the amp. then no worry about battery drain. i dont know how long a battery will last powering a amp with the car off so this is a easy solution to give me peace of mind.
  11. #51 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    Noobs in car audio...... :-/. Cant fix stupid i guess!!
    Some will learn most will not
  12. #52 Re: Putting in a switch for subwoofers
    Jun 2011
    ontario
    so your saying if ya turn down the volume then there is no power going to the amp? or just not enough to worry about the battery getting drained?
    Buffalo
    There is soo much over thinking in this. Makes my head hurt
    If your car dies from running the stereo for a few minutes with the car off, it's 2 things
    A **** battery or a massive system
    Or your cranking up the volume with the car off
    Get yourself a nice red top. It will have the reserves to take the hits from the amp. Your lights should never dim at idle at a light. Even with the system pounding.
    I wanna take a video of my gauges and amp at idle. You would be amazed. 14.1-13.8
  14. #54 Re: Putting in a switch for subwoofers
    Nov 2008
    Waterloo, Iowa
    I've contemplated a switch, but only because cops around here have a hard-on for loud music, and an instant killswitch totally puts me off the map the second I see a cop. Still have yet to do it, may never do it. Other than that I agree with there being not a single reason for a switch...
  15. #55 Re: Putting in a switch for subwoofers
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    he is saying he turns his amp off and keeps the volume low when the car is off.
  16. #56 Re: Putting in a switch for subwoofers
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by tc300 View Post
    Wow don't you sound like a dick. Really understand why people are hesitant to ask questions when people like you speak to other members like this. He doesn't understand. We have all been there. If your not going to contribute a suggestion or helpful comment then don't Post. I'm so tired of people like you. I really am. And the worst part is, I'm sure you don't know anything about car audio or electricity, just read a few threads and you think your an expert. I have news. I have had 5 years of higher level electrical engineering classes and I still have a ton to learn about car enginering. So please. Just shut up.
    Infinity all around.
  17. #57 Re: Putting in a switch for subwoofers
    Tell me why the capacitor is a stupid idea. Give me a reason. We're trying to help people here. I would be willing to get you don't even know what a capacitor accomplishes in the car audio setting. Unless you have a reason to say something, don't. You just sound ignorant and misinformed.
  18. #58 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    Quote Originally Posted by chamilton89 View Post
    Hey dummy... Go look online at the car audio forums and just how many ppl use caps... Theres a reason for it!!!DUUUHHHH
    If i want or need more juice and a xtra battery... Big 3 upgrade... HO alt... But you ppl wana use a caps..??!! GTFOH
  19. #59 Re: Putting in a switch for subwoofers
    Do we only cover the exact same topics over and over again?
    Oh who am I kidding... its GPF.
  20. #60 Re: Putting in a switch for subwoofers
    GTP Level Member
    springfield IL
    Me..and expert..?!? Lol. Uummmm no... Nice try. Who gives a F about u and "electrical class BS"!! If was to mis inform the op, i would of said "hey! What a great idea to use a cap!". No i told him the truth! Caps are TOTAL WASTE! You prolly work at best buy or circuit city dont ya..??
    Sounds like u been hangn with charlie sheen banging 7gram rocks!!!!
    L M F A O!!!!!!
  1. So Who go F***ed on this deal? Subwoofers...
    By Brian99SE in forum General Grand Prix Discussion
    Last Post: 01-11-2012, 02:28 PM
  2. Can't get key out after putting car in park.
    By Dusty02se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2010, 02:44 PM
  3. Putting Motor In
    By dcbur2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2009, 10:44 AM
  4. 10 inch digital dynamics subwoofers
    By gtpinsc in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 02:20 PM
