Thread: Fitting two ported T2's...
Results 1 to 3 of 3
  1. #1 Fitting two ported T2's...
    Pennsylvania, USA
    Well, the title pretty much explains it, I want to attempt to make an enclosure that will actually fit my car ('05 GP GT), hold two 12" Rockford Fosgate T2's (unless anyone has better recommendations), and is tuned low.
    And when i mean low, I mean no higher than 30Hz, maybe a tad lower. My current box housing two 12" RF P3's is tuned between 33Hz-38Hz (very steep roll off after 33Hz), and I really want to get some new subs that both play MUCH louder, and hit any low note you throw at it (except for maybe like, organ notes). There have only been a few songs that my subs struggle with, but as a bass head this annoys me regardless...
    Power shouldn't be a problem, I've already got a good HO alternator, as well as a dry cell up front and a second in back isolated, powering a 1400 watt rms amp -> Amazon.com: Massive Audio N3 Mono Block Amplifier 1400w x 1 RMS @ 1 ohm: Car Electronics Puts out it's rated power in spite of its tiny size. I figured get another battery and a second one of these amps, and run each T2 off of a separate amplifier.
    So overall I'm just very worried about constructing the box, because even if I can get it to fit, it's going to have to be an odd shape and I've never built my own ported box before.
    Again, if anyone has any better recommendations, especially if it lowers the size of my box, it's greatly appreciated. I'd settle for one T2 as long as it's still louder than my two P3's, I just want louder and lower :D
  2. #2 Re: Fitting two ported T2's...
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    1 15" Fi BTL running on that 1400w rms..
    Just my preference
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  3. #3 Re: Fitting two ported T2's...
    Pennsylvania, USA
    I was actually looking into Fi's BL and BTL, but I feel like they're just too obvious when ported. Like SQ goes out the door really quick, and I know it's hard to maintain with vented enclosures, but I want to still be able to hit double bass. My P3's currently make metal sound like a submachine gun, and I couldn't bear to lose that.
    That is unless the Fi could hit accurate double bass, then I'd be all for it, I feel like it would be close to the two T2's spl from what I've seen. They get SO LOUD.
    Edit: Just out of cuiousity, anyone have any experience with the Fi Q's? I feel that due to my limited space sealed is something I should look into, but how would 2 sealed 12" Fi Q's compare to my ported 12" P3's? I know ported will give way more spl usually, but the power handling is over twice that of the P3's. However I'm not sure if sealed would play as low as I'd like...
  1. which fitting is which?????
    By chancinit666 in forum General Tech Discussion
    Last Post: 12-11-2010, 11:58 AM
  2. FPR vac fitting
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 11:50 PM
