Thread: HELP!
Results 1 to 9 of 9
  1. #1 HELP!
    Jan 2012
    Covington Wa
    Where did some of you put your ground wire for your amp and when i hook up the wire for the power where should i put that?
  2. #2 Re: HELP!
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    i drilled a hole in the spare tire area w/ a washer and bolt screw for the 4ga ground.... and rand the power from batt thru where the shift cable goes thru the fire wall under all the carpet to the trunk
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: HELP!
    Jan 2012
    Covington Wa
    OK sweet so there is nothing underneath the spare tire area and where do attach the power i know the positive but on the positive wire were there is a fuse box below it or?
  4. #4 Re: HELP!
    brunswick
    for the amp?? to the positive terminal on the batt
  5. #5 Re: HELP!
    Jan 2012
    Covington Wa
    ok sweet thanks
  6. #6 Re: HELP!
    brunswick
    welcome
  7. #7 Re: HELP!
    GTP Level Member simbah's Avatar
    Lala land
    I hooked up my ground to one of the strut mounting bolts, I've heard that this is a popular place to ground to.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  8. #8 Re: HELP!
    Oct 2011
    Toledo, OH
    Quote Originally Posted by simbah View Post
    Me too.
    7"
  9. #9 Re: HELP!
    Jan 2012
    Covington Wa
    Thats what i was thinking you guys just throw another bolt on there or just take the one on there off enough to put the ground on
