Thread: Lights dim when my bass hits.
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Lights dim when my bass hits.
    SE Level Member ttjj1410's Avatar
    Nov 2011
    fairbanks, ak
    hello all. i have an issue with the lights on my 05 GP dimming when the bass hits. i have all leds on the car inside and out to reduce power consumption on the alternator and because they look really good. i have 1 memphis 12" with a 200 watt amp. also this is a relatively new issue as it didnt do this when i lived in georgia and has started since moving to alaska. any advice on this is greatly appreciated as i dont want to damage any electronics in the car. thanks in advance
  2. #2 Re: Lights dim when my bass hits.
    Pennsylvania
    You ran the power cord on top of the interior lighting wiring. EMP, broski. I don't see any way around interior lights dimming unless you run the power wire around a different part of the car.
    now if your headlights are dimming... Turn something down.
  3. #3 Re: Lights dim when my bass hits.
    I live here. TLSheff's Avatar
    Quote Originally Posted by ttjj1410 View Post
    I would GUESS that your amp is working too hard and pulling alot to keep up the sound your trying for. If its maxed and your cranking your stereo up its just got a major draw on the battery and alt. You would probably do better with a bigger amp that could be turned down and a decent capacitor to help out.
    Back in the day I had a 600watt Memphis 600-c amp pushing 2 PR 12's in my truck, with the capacitor my headlights stopped dimming because it took some of the draw, but if I really cranked up the amp it wouldn't matter. But usually a 200 amp wouldn't pull that much so I'm not 100% sure.
  4. #4 Re: Lights dim when my bass hits.
    Pennsylvania
    wut
  5. #5 Re: Lights dim when my bass hits.
    capacitors dont work. you need a higher amperage alternator.
  6. #6 Re: Lights dim when my bass hits.
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    You're right to an extent. Not to say you are wrong. Capacitors DO provide some function as a Filter and does smooth out the power drop to a less noticeable extent. Which may make it seem like the car is not straining as much as it did without. yet there is still a massive voltage drop.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  7. #7 Re: Lights dim when my bass hits.
    GTP Level Member
    Nov 2011
    Kansas
    Bigger wires, and check or get new alternator.
  8. #8 Re: Lights dim when my bass hits.
    how is a higher amp alt gonna help when he's hardly pushing any power?
  9. #9 Re: Lights dim when my bass hits.
    GTP Level Member
    Nov 2011
    Kansas
    To the OP, what size of wires are you running?
  10. #10 Re: Lights dim when my bass hits.
    Out West
    just means the car appreciates the jams.
    Whine with your Cheese?
    Stock+Self Tuned. Going for low 14's everyday.
  11. #11 Re: Lights dim when my bass hits.
    Omaha, NE
    Turn the amp down.
  12. #12 Re: Lights dim when my bass hits.
    Pennsylvania
    Wait... does nobody else's interior lights dim when their bass hits? Am I doing it wrong?
  13. #13 Re: Lights dim when my bass hits.
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Quote Originally Posted by SlowNA06 View Post
    Mine do, and my voltage drops from 13.7 to around 12-12.5
  14. #14 Re: Lights dim when my bass hits.
    Pennsylvania
    Quote Originally Posted by cameron92 View Post
    I bet your headlights dim. Mine don't. Don't think my voltage drops below 14-something.
  15. #15 Re: Lights dim when my bass hits.
    Nov 2008
    Waterloo, Iowa
    My headlights don't dim where as the rest of my lights do, pretty greatly, on my 1000watt amp. 4GA wire with a 120amp fuse, amp is fused at 80amps. But even my old amp with the 25A fuse did that as well.
    Big 3 upgrade, that should fix it.
    In my case my car is so power-f*cked that I don't think I'll ever NOT have issues. -_-
  16. #16 Re: Lights dim when my bass hits.
    Nov 2008
    Waterloo, Iowa
    I heard capacitors put strain on the alt. I'm not sure how, but that turned me away from ever getting one.
  17. #17 Re: Lights dim when my bass hits.
    Pennsylvania
    Can't imagine how big a cap setup you'd need to do that, but any reason's a good one.
  18. #18 Re: Lights dim when my bass hits.
    Dec 2011
    Cadiz, Ky
    Only feasable time i could see that it could put a strain on any components is inital power up from 0V But they normally have a resistor for a longer Time Constant charge. Say Its a 1 Farad CAP with a 50 OHM resistor... T=50*1 Where Time=Resistance(Ohms) * Capacity (Farad)
    Which would mean the capacitor would be 63% of supply voltage 8.72 volts for a 13.8 volt supply after 50 seconds.
  19. #19 Re: Lights dim when my bass hits.
    what is the definition of a farad?
  20. #20 Re: Lights dim when my bass hits.
    Dec 2011
    Cadiz, Ky
    Unit (ISU) of capacitance in laymans terms.
  1. Light pulse when amp hits
    By BeastGT in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2011, 11:58 AM
  2. E85 Turbo'd GP hits the dyno!!
    By glanzergtx in forum General Tech Discussion
    Last Post: 08-07-2010, 06:38 PM
  3. 1997 gtp sometimes only hits 4k rpm
    By KOOLJAYONE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2010, 02:05 PM
  4. Best Bass CD
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2009, 04:44 AM
