Thread: 2008 GP with Monsoon System
Results 1 to 3 of 3
  1. #1 2008 GP with Monsoon System
    Dec 2011
    South Dakota
    I have currently set up subwoofers in my car. I had to use a line output converter to get an rca signal using the rear deck speakers. I have also hooked up a wired fm transmitter to play my ipod. it works ok, but i had the exact same subwoofers and amp in my old car, but hooked up to a kenwood head unit, not the factory unit with adapters, and the quality was much better. I would like to put this kenwood unit into my new car but i understand that there are problems with removing the factory unit. How do i retain the onstar capabilities as well as the DIC center. i have heard that the factory unit is required to run the trip computer and other functions on the DIC, all of which i do not want to lose. Is there any way to do this with an aftermarket head unit.
  2. #2 Re: 2008 GP with Monsoon System
    Omaha, NE
    The date and time are stored in the factory radio so you'll lose those no matter what. Everything else from the dic and onstar will remain as long as you get the right wiring harness.
  3. #3 Re: 2008 GP with Monsoon System
    Dec 2011
    South Dakota
    Hey man thanks for the quick response. So all i need to do is get the correct wiring harness, the GMOS 4?
  1. No sound after radio install..2004 Monsoon system. Need quick help
    By nickleahy23 in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2012, 08:47 PM
  2. Monsoon System stopped working just tweeters work
    By Shadowz89 in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2011, 08:37 PM
  3. help with monsoon system
    By chrisp847 in forum Audio, Security & Visual Electronics
    Last Post: 02-11-2009, 02:19 PM
  4. 2008 GP charging system lights
    By RadoZ71 in forum General Tech Discussion
    Last Post: 01-20-2009, 02:02 PM
  5. Need help with Monsoon sound system please
    By Keith04gp in forum General Tech Discussion
    Last Post: 09-29-2008, 04:51 PM
