Thread: aftermarket headunit in 06 gxp
Results 1 to 7 of 7
  1. #1 aftermarket headunit in 06 gxp
    GT Level Member nicks98gtp's Avatar
    michigan
    im trying to find an answer on this for a buddy, i guess he was told by ABC wearhouse that he couldnt put an aftermarket headunit in his 06 gxp (doesnt have nav, but has 5 button dic, and monsoon) because the DIC wouldnt work anymore? I have never heard of anything like this can anyone shine some light on if this is true or what would have to be done. thanks in advance
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: aftermarket headunit in 06 gxp
    St. Cloud, MN
    Use the search feature....
    It will work.
  3. #3 Re: aftermarket headunit in 06 gxp
    Omaha, NE
    He will lose the day, date and time settings, besides that everything else will remain functional.
    There's a few threads on this. Its an issue with any 04+ Grand Prix.
  4. #4 Re: aftermarket headunit in 06 gxp
    Oct 2011
    Toledo, OH
    And door/key chimes.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  5. #5 Re: aftermarket headunit in 06 gxp
    Omaha, NE
    Quote Originally Posted by industrialfish View Post
    AFAIK That depends on the wiring harness used.
  6. #6 Re: aftermarket headunit in 06 gxp
    michigan
    i did read about the door chime, etc which is no big deal. Thanks for the help guys, I did my system in my 98 and it was much easier without having the monsoon and stuff.
  7. #7 Re: aftermarket headunit in 06 gxp
    GTP Level Member
    Nov 2011
    Kansas
    My 08 still has those... It depends on what harness you use.
  1. Best Aftermarket Headunit?
    By ajc549FF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2011, 01:01 AM
  2. Aftermarket speakers w/stock headunit
    By vstar in forum Audio, Security & Visual Electronics
    Last Post: 08-04-2010, 09:27 PM
  3. 2004 monsoon + aftermarket headunit
    By blabo219 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2010, 03:10 PM
  4. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
