Thread: Need Help Installing Subs in 05 Grand Prix
Results 1 to 20 of 29
  1. #1 Need Help Installing Subs in 05 Grand Prix
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    hey guys, i just got a 2005 grand prix today (excited! its my first car, a hand-me-down from my mom) but i was also given a set of two 12" subs from a friend of mine a year or so ago. and im looking to install them in my Grand Prix. it does NOT have the monsoon system or the sterring controls. i was originally going to install and after-market head unit as well but found that the adapter was about $100 extra. so i want to just hook them up (with an amp) to the stock head unit. to do this i know you need to use a Line Output Converter. i also know you need to tap into the rear speaker wires. im not sure on how to do this though. you dont lose your rear spearkers do you? any pictures or videos would be excellent help! also where is a good place to put the power wire through the firewall? thanks in advance for all the help! stupid adapter through everything off. i knew how to set em up with an external head unit
  2. #2 Re: Need Help Installing Subs in 05 Grand Prix
    Destroys cars izup69's Avatar
    Iowa
    Hey you can get a cheap harness for like $30 but you will loose your door chimes. I routed my 1/0 gauge wire though the firewall on the driver-side there is a rubber grommet plugging up a hole nothing is running through it. I just used a utility knife and cut a x into it ran it though there. Yes I know the car is very dirty. After it gets in the car it just runs along the floor under the back seat and into the trunk. I will eventually run it under the carpet all the way to the trunk.
    This shows it running across the firewall it used to be tied up nice and neat but since the car is not running atm I uncliped to work on some stuff
    Here is how I got it routed behind my fuel lines and down beside the break booster
    The blue wire is my power for the amp it runs down underneath the brake booster I couldnt get a good pic of the grommit but it is right by there it is easy to find by feeling
    Here is where it comes into the car right next to the steering collum
    The peace pulled down is the carpet
    I just cut a hole in the carpet to run the wire though so it would not interfere with the gas peddle
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  3. #3 Re: Need Help Installing Subs in 05 Grand Prix
    Jul 2010
    Dubuc, SK
    Hey, the line out convertor is quite simple, you just tap into the positive and negative of each rear speaker. I am not sure of the color codes for which is positive and negative off hand, but a quick search should find that for you. Also, there is a better grommet closer to the passenger side near the middle where all the engine bay wires come through. I was able to run three runs of 4 gauge through there, so there is plenty of room. then you can run it on the passenger side under the door sills so it is a shorter run.
  4. #4 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    thanks guys. for now i dont have an amp and just used speaker wire from the subs to the wire going to the rear speakers. it seems to be working fine until i can get the money for the amp and everything else
  5. #5 Re: Need Help Installing Subs in 05 Grand Prix
    SWPA
    You can actually hurt the subs hooked up that way. Too little power is just as bad, if not worse, than too much.
  6. #6 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    how bad? the subs are very cheap low end ones i got for free from my friend. 50-150 rms. 800 watts peak. and i had them hooked up to the radio in my room for probably a year or longer aswell.
  7. #7 Re: Need Help Installing Subs in 05 Grand Prix
    SWPA
    Its not something I would ever chance. You could smoke the subs and in turn cause it to short your headunit.
  8. #8 Re: Need Help Installing Subs in 05 Grand Prix
    Pennsylvania
    I think most people run the power wire through the rubber grommet in the footwell of the front passenger seat. Just pop off the plastics and run it along the other wires there. No need to cut up your carpet.
  9. #9 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    alright thanks for the advice
  10. #10 Re: Need Help Installing Subs in 05 Grand Prix
    GTP Level Member
    springfield IL
    I wouldnt waste time installing a line converter.... Put that money towards a nice deck!!
  11. #11 Re: Need Help Installing Subs in 05 Grand Prix
    SWPA
    By the time you put the money towards the deck, and all the harnesses, its not worth it in my opinion. I have a nice Alpine unit just sitting in my closet because I am not about to spend as much as I did for harnesses as I did on the headunit just to be able to have pre outs. I'm going the line converter route myself once I replace my sub.
  12. #12 Re: Need Help Installing Subs in 05 Grand Prix
    GTP Level Member
    springfield IL
    Geezz... Some of you ppl dont like sq of a stereo...
    LC's most of the give clipped signals to you subs/speakers!! Fyi that mean you will fry something! :-)
    Im not familiar with the newer Grand Prix, mite find a good local shop to have a deck installed...?
  13. #13 Re: Need Help Installing Subs in 05 Grand Prix
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Wouldn't waste money? Around here they are only like 20-30 bucks not that much to put towards a headunit.
    On another note like said previously don't run the subs without an amp. You will blow up your headunit.
  14. #14 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    would that be why my old stereo i was using it on stopped working??
  15. #15 Re: Need Help Installing Subs in 05 Grand Prix
    SWPA
    Very well could be.
  16. #16 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    never would have thought that. i just wont tell my mom that..
    i uninstalled my subs for now, cant hardly tell the difference since they werent amplified, no need to risk tearing up my head unit too.
    what all is lost on the 05 gp when you install an external hu?
  17. #17 Re: Need Help Installing Subs in 05 Grand Prix
    GTP Level Member
    springfield IL
    Not sure what you will loose... Just google it.
    Line converters are a huge waste of money take the better route buy a good head unit! :-)
  18. #18 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2009
    The only thing you will lose will is the date and time but that is on the head unit most of the time.
  19. #19 Re: Need Help Installing Subs in 05 Grand Prix
    Nov 2011
    Decatur
    alright thanks guys
  20. #20 Re: Need Help Installing Subs in 05 Grand Prix
    Feb 2010
    St. Louis
    Or instead of wiring through the firewall, you could do what I did. On the passenger side, there is a hole by the door jam that runs all the way up the inside of the fender and then there is another hole right next to the battery. The wire is slightly visible though where the door closes, but its not noticeable unless you are looking for it. Only thing is, this might not work if you're using 0 gauge or something cause the door might not be able to shut
  1. Installing OEM foglight on 2004+ Grand Prix
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 10-18-2022, 03:22 PM
  3. Installing sub in 99 grand prix gt
    By protoplayer in forum Audio, Security & Visual Electronics
    Last Post: 08-01-2011, 07:11 PM
  4. Installing subs
    By bilak09 in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2010, 10:33 PM
  5. 2007 grand prix installing after market CD player
    By slimhero in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2009, 10:57 PM
