Thread: adding subs with factory head unit
Results 1 to 2 of 2
  1. #1 adding subs with factory head unit
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    i have a 2005 grand prix i had a 2000 i dunno if its the same cuz the 2000 had a bose and the 05 got a moonson
    previous i used the pink wire for the remote wire could i still do tht on the 05
    and with using a line out converter what wires do i come out of there are blue black yellow and another color i kno u gotta come outta the left rear but wht wires??
    and if there is a better way which is the better way
  2. #2 Re: adding subs with factory head unit
    Omaha, NE
    04+ stereos don't have a remote wire built in. You'll have to use any ignition switched wire or fuse you can find.
    The positive and negative wires are the ones you will want to splice into for the line out converter.
  1. stock head unit with subs and ipod hookup?
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2010, 09:50 PM
  2. Help with factory head unit 2004 gtp
    By playa12 in forum Audio, Security & Visual Electronics
    Last Post: 05-24-2010, 06:54 PM
  3. how do you hook up subs with stock head unit?
    By peej1108 in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 04:57 AM
  4. Adding a sub With out changing head unit
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 01-11-2009, 08:15 PM
