Thread: Woofer Position Question(update-new problems/ideas)
Results 21 to 40 of 74
  1. #21 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    Quote Originally Posted by GTPSHAWTY View Post
    well my input.. the speaker shouldnt be switched around unless its a free air type of speaker... and as far as the bass knob... just set ya bass where you want it... and leave it alone.. moving it up and down will eventually short out the amp sooner or later... get an eq for all that... you will be much more satisfied
    The voice coil is still dealing with back pressure from the box since the cone is still attached to it's air space/receiving back pressure. So it really isn't like dealing with IB in any way shape or form.
    Inverting the speaker is changing the phase 180 degrees WITHOUT adding any "delay". If you flip polarity on the sub then you change the signal 180 degrees AND delay by one wave length. It's easier to demonstrate than talk about.
    11 is louder than 10!
  2. #22 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    i want i knob to control it,
    i use it everyday, some songs i want massive bass and other i dont and everything in between
    so i need one
    i have had the same set up for 4 years and everything still works and sounds like new
    only problem ive had is the bass knob thingy
    couple questions
    how do you know if the HU has sub control?
    my box is big and open and 1' thick mdf so what does it matter if one sub is out and the other is in?
    Technically speaking, the kick of bass is determined by your mid speaker and how well it matches up with the sub. That means install and tuning are paramount! You can EQ your tweeter and change the sound of "bass"
    Go to an audio competition and listen to different setups. Notice their mid configuration in comparison to subs.
  3. #23 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Apr 2011
    Athens, AL
    He's using the knob probably between different kinds of music and probably wants to keep it that way. I'm keeping my stock unit so I needed to get a level knob or some music just wouldn't sound right. Someone said that the knob would short the amp out and that it should be left alone - why would there be a 15' cord to put by a driver seat if it shouldn't be used. I don't know about his but mine just adds a potentiometer inline with the level on the amp so the knob can only turn the amp as high as set on the amp. However, remote bass boost can hurt an amp when turned up a lot.
    To OP, you're best bet is to get you another knob. If you have an aftermarket head unit, many of them have a subwoofer control in the music settings that allow you to set it from like -3 to +3 which would give you the type of control over the bass you are looking for. But the amp gain should gave been set with this turned up if you plan to use it. Any eq setting you use on the hu should be factored in when setting gain. Most write-ups say to use a flat eq which is great but when you change all the settings you can then clip the amp.
  4. #24 Re: Woofer Position Question(update-Position is done with now on to more problems)
    yes^
    i can change all that in my HU but its easier and more convenient just to control it with the knob
    my sub level on the HU goes from -6 to +6 and i was told to put it at -6 my the shop i go to but i didnt like that so its at +4 now
    this is was my amp says(settings on the side)(easier just to post a pic)
    the gain is just both max and the low pass is at 50hz and where it says remote is where the knob goes
    SMGPFC Member #10
  5. #25 Re: Woofer Position Question(update-Position is done with now on to more problems)
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    turn ya amp off full it will keep trying to throw words out the woofers.. will also mess them up too.. put it on lph... and feel more bass
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  6. #26 Re: Woofer Position Question(update-Position is done with now on to more problems)
    ive been tryin to figure that out for years, the shop that installed it setting it like that and the only setting ive changed is the gain
    SMGPFC Member #10
  7. #27 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    dam... everytime i buy somethin.. ill sit and play with every feature to learn it... but flip the switch and see what you get.. then mess with the gain.... and the low pass knob
  8. #28 Re: Woofer Position Question(update-Position is done with now on to more problems)
    so do i, but i was 15 when i got it and my dad paid for it and i didnt want to **** it up,
    imm flip it when i get it hooked up, my speaker wire is to short to go around the box so i had to fix that first
    SMGPFC Member #10
  9. #29 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    o ok...just post on here the difference when its done
  10. #30 Re: Woofer Position Question(update-Position is done with now on to more problems)
    got everything hooked back up and flipped the X-over to lph so will see.
    SMGPFC Member #10
  11. #31 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    Flip phase to 0.
    Set LPF to ~80hz. Then try ~120hz.
    Inside the box...does each speaker have it's own chamber? Or do they share common air space? Flip the + and - wires on one of those subs if they share common air space.
    Shared/common air space(disregard the port)
    Separate chambers/air space(disregard the port)
  12. #32 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    i myself have 3 12's in a shared airspace and it sounds dam good...
  13. #33 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    The issue is with polarity. As far as I'm concerned I'd rather have separate chambers for all of my speakers.
  14. #34 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    Panasonic hu memphis xover 1500d quantum monoblock amp.... two offbrand autotek 12s and one ragedy punch 12 all is hooked up + to + and - to -
  15. #35 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    This might be harsh but I'm not examining your setup. If you like your sound, that's great, but that's not the topic at hand.
    If this kid has two woofers sharing common air space but facing different directions it's necessary to reverse polarity before something is damaged because he can't "hear" anything due to the cancellation. Next thing you know...gain goes up, bass boost goes up...BOOM!!!!
    Honestly, even if they do maintain separate chambers there's probably cancellation. They need to play together, not AGAINST each other.
  16. #36 Re: Woofer Position Question(update-Position is done with now on to more problems)
    GT Level Member GPGT4dr's Avatar
    Nov 2011
    Corinth, Mississippi, United States
    Just get a DD9512, or a Sundown nightshade. All you need is one to get you near 150db!
    Jay-D (Aka DJ Jack Ripper - Look it up on facebook!)
    1999 GPGT Sedan, 3800S2, black with MOST options :/
  17. #37 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    when i hear this problem i usually tell ppl to go thru their wiring.... and make sure NOTHING is backwards.. second i say look at the amp and make sure its on lph.... check ya wires.. if you got over 1000 watt setup get thicker wire.. for better crisp sound.. idk about all that im just a backwoods music guy.. im not with crossin or reversing nothing lol just hwo i am
  18. #38 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Feb 2009
    Virginia
    I understand...I'm a very methodical person. I try to take into consideration the science as well as the fact that there isn't any real way to guesstimate what will happen.
    Car audio is one big guess. But I certainly understand cause and effect in this specific matter. Since most people don't have any idea what they're hearing anyways, they don't notice cancellation, second and third order harmonic distortion, etc, etc. Even if they do notice it and it's technically bad...they usually think it's "good" just because it sounds different. But in the end if they're happy it doesn't matter!! So I pick and choose when I chime in. I see this as a potential bad circumstance for the op that I'd like to help him avoid.
    I just like to try and educate those who have questions. Your opinions are definitely welcome and thanks for chiming in! Hope I don't seem like too much of an ass D:
  19. #39 Re: Woofer Position Question(update-Position is done with now on to more problems)
    brunswick
    Quote Originally Posted by I800C0LLECT View Post
    nope you didnt just taught me things i didnt know
  20. #40 Re: Woofer Position Question(update-Position is done with now on to more problems)
    Nov 2011
    Another great site is Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers. I think that's it anyways... I learned a lot about wiring, phasing, the works... If you have a little time to read, check it out.
  1. Cam Position Sensor
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 08-23-2011, 04:21 AM
  2. sub woofer pre amp out on factory Delco?
    By quijibo in forum Audio, Security & Visual Electronics
    Last Post: 07-13-2009, 10:10 AM
  3. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  4. IAC Position
    By Reptile in forum PCM Tuning
    Last Post: 03-08-2008, 02:21 PM
