Thread: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
Results 1 to 8 of 8
  1. #1 Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    Troy, Michigan
    Hey guys, bought a 3-gauge pillar pod..I need some cheap gauges to fill them up for now before I get the expensive ones...at autozone they have the sunpro brand...I wanted to run a oil pressure gauge, volt, and not sure about the third? But if I were to buy these..can I wire them straight from the package? I think i remember hearing the oil pressure sensor is behind the passanger front wheel by the oil filter...how would I hook this up? Thanks guys!
    1999 Grand Prix GT - Red 8000k heads/fogs-flipped doggy bones. Looking for polished GTP wheels from a local in michigan. PM ME!
    l
  2. #2 Re: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    Troy, Michigan
    Anyone? :'(
    l
  3. #3 Re: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    the third gauge is going to be a 'useless' gauge anyway. trans temp might be your best bet for something fairly useful.
  4. #4 Re: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    Florida
    Why buy cheap gauges for the time being?? Why not just get 1 nice gauge until the other 2 nice ones come along??
    I ran Oil pressure, volt meter, and trans. temp. Later swapped out the volt meter for an Aeroforce..which is awesome.
    And you unthread the sensor by the oil filter, and thread in the new sending unit.
    Oil Gauge Installation <--The write-up I used to install mine.
  5. #5 Re: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    I've used mechanical gauges and never had a problem with oil leaking.. Just have to use grommets in the fire wall so you don't chafe the line...
    Snorlax strikes again.
  6. #6 Re: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    Portland Oregon
    Quote Originally Posted by RamairGTP2 View Post
    You won't pass tech at the dragstrip if you like to race your car. They won't allow engine oil past the firewall in any form.
  7. #7 Re: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    Troy, Michigan
    Hey thankyou for the responses! I wanted to fill in these holes for the time being until I get an aeroforce. I have a mechanical oil pressure gauge but the hose for the oil seems way too short to reach the oil sensor by the oil filter
    l
  8. #8 Re: Sunpro gauges...h8rs gon h8...i need the cheap sthuff
    Quote Originally Posted by OH4CompG View Post
    I don't race this car at all....
    When I used to take my 90 cavalier and 91 grand am to the strip, I had the mechanical oil pressure gauge in both... They never really bothered with it...
  1. Gauges
    By 99prixgt in forum General Tech Discussion
    Last Post: 09-25-2008, 11:48 PM
