Thread: Help on an Amp
Results 1 to 4 of 4
  1. #1 Help on an Amp
    SE Level Member HuskerFan95's Avatar
    Oct 2011
    Nebraska
    So here's the deal, I have two 12" Kicker Comps (8 ohms) in a ported box. The Max Watts Peak is 300 and the Max RMS is 150. I need help with choosing the right amplifier for these subs. Can someone point me in the right direction of choosing an accurate and slightly affordable amp to power these subs? Thanks!
  2. #2 Re: Help on an Amp
    Sep 2011
    seattle
    any amplifier that can do the rms rating w/ the ohm load is good also try to get a slightly larger amplifier due to heat stronger amps than whats need generally tend to operate cooler an sound better good luck
  3. #3 Re: Help on an Amp
    Oct 2011
    Nebraska
    Do you have any suggestions as to what brand or model of amp I should get? I'm totally lost on what amp to purchase.
  4. #4 Re: Help on an Amp
    Feb 2009
    Virginia
    Could you provide model numbers of the hardware in question?
    In terms of music, majority of the information is in your mid-range. However, it's not noticed as much as the impact you get from adding a subwoofer. Remember, that the sound of your sub is shaped by the mid-range response in your vehicle.
    As long as you setup and install correctly I'd grab anything that puts out around 300 watts. In car audio, power specs are bogus. The goal is to get a good strong power supply in the amplifier.
    Here's a great deal and has some flexibility in terms of use...
    Aura RPM2300 RPM Stage 2 Mobile Amplifier 2x150W 269-189
    11 is louder than 10!
amp
