Thread: Light pulse when amp hits
Results 1 to 5 of 5
  1. #1 Re: Light pulse when amp hits
    Sep 2011
    Arkansas
    LEDs - underbody kits, cathodes, flexible LED strips, dome lights
    They have hardware that can handle what you want. Also, if you must do tubes, I'd recommend CCFL (cold cathodes) or LED tubes. Personally, I use the LED strips in my vehicle, as I find them easier to hide (I can't STAND seeing the source of the light). Look for the music interface... that will give you your desired light response. As for just using the illumination at night, a simple rocker switch will do.... when you run your +12v to the lights, simply put a switch somewhere convenient for you... presto, you're done. That site also has some ok forums, so I'm sure any other questions concerning vehicular illumination can be handled there as well.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  2. #2 Re: Light pulse when amp hits
    SE Level Member BeastGT's Avatar
    Aug 2011
    Palm Coast
    Could i use 1 switch for about 6 strips of LED. How would i set this up
  1. How-to add LED's & have them pulse from amplifier
    By mousemonster1232 in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2011, 06:46 PM
  2. need help asap no injector pulse 5th cyl
    By jenkins6586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:47 PM
  3. E85 Turbo'd GP hits the dyno!!
    By glanzergtx in forum General Tech Discussion
    Last Post: 08-07-2010, 06:38 PM
  4. 1997 gtp sometimes only hits 4k rpm
    By KOOLJAYONE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2010, 02:05 PM
  5. Pulstar pulse plugs?
    By a98gtp4u in forum General Tech Discussion
    Last Post: 09-20-2009, 08:47 PM
