Thread: Upgrading Speakers from base to monsoon???
Results 1 to 15 of 15
  1. #1 Upgrading Speakers from base to monsoon???
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    so i have a base grand prix with the base sound system not the monsoon. i recently upgraded my head unit to a nice pioneer unit aswell as have two 12's in the trunk. one of my good friends dads owns a junk yard so if there is a grand prix with the monsoon speakers i could get them real cheap if not even free, would it be worth it to upgrade my door and rear speakers from the base to the monsoon ones, especially if i can get em free?
    also how easy would the instalation be? if im taking them out of a gp and puttin em in another gp it should just be un plug from the one and plug em in the other right??
  2. #2 Re: Upgrading Speakers from base to monsoon???
    Yoga city
    if you have the base i believe you need the whole harness. so plug n play is prolly out the question. why would you do that anyway? jsut get a nice four channel and some componets and go to town.
  3. #3 Re: Upgrading Speakers from base to monsoon???
    Nov 2011
    Decatur
    dont really want to spend the money to buy new speakers and an amp at the moment, just spent a lot on the head unit and subs. also i dont know what size speakers are in the older models but could i use even the bose ones out of them?
  4. #4 Re: Upgrading Speakers from base to monsoon???
    Houston
    Quote Originally Posted by Jteske88 View Post
    lol, cuz free.
    Quote Originally Posted by 2dee11 View Post
    No, the harnesses are different. Even if they were the same, I believe the monsoon speakers run at 2 ohm and not a lot of head units can handle that.
  5. #5 Re: Upgrading Speakers from base to monsoon???
    London Ont, Canada
    stock speakers are not terrible, just wait until you have the dollars to buy real speakers.. Even monsoons are poop
  6. #6 Re: Upgrading Speakers from base to monsoon???
    michigan
    The bose system comes with a factory amp that youll need to wire up to get decent sound (along with the reasons stated above). Im not a system guru, just letting you know there are other components to the sytem that you may need to consider. I highly suggest aftermarket, its new and will most likely sound much better than junkyard audio!!
  7. #7 Re: Upgrading Speakers from base to monsoon???
    Yoga city
    i have a fully loaded gp and reccomend getting rid of stock it sucks for any type of sq. if you want mono tone sounding speakers go with stock
  8. #8 Re: Upgrading Speakers from base to monsoon???
    Pennsylvania, USA
    The Monsoon doesn't even sound as good as my coaxial Infinity Kappa's, save some money for real aftermarket speakers and an amplifier, you'd be disgracing the clean output of your HU by sending the signal to the Monsoon, just so it can make it sound crappy.
    Really though, listen to a stock system and then a Monsoon. There's definitely an improvement. Then listen to the Monsoon followed by a real system, even bigger improvement.
  9. #9 Re: Upgrading Speakers from base to monsoon???
    Banned
    Sioux Falls, SD
    My monsoon has really good bass, i upgraded front speakers, but i love it for being stock
  10. #10 Re: Upgrading Speakers from base to monsoon???
    May 2008
    Winnipeg, MB
    You would need the monsoon amp as well. Then new door panels for the tweeters as I don't think the base model has tweeters?
    2007 Pontiac Grand Prix
  11. #11 Re: Upgrading Speakers from base to monsoon???
    Banned
    Sioux Falls, SD
    Im not sure if the wiring harness is there in a base car. You'd be better of going aftermarket
  12. #12 Re: Upgrading Speakers from base to monsoon???
    May 2008
    Winnipeg, MB
    Midnightblue, did you install the front speakers yourself? and if so how did you do it?
  13. #13 Re: Upgrading Speakers from base to monsoon???
    Apr 2011
    Cleveland,OH
    2dee11 to answer your question no it would not be worth it at all to upgrade your speakers to Monsoon for a few reasons
    1. As previously stated your new headunit puts out a higher quality signal then the monsoon amp will reproduce; you would just be making it dirty again
    2. You would need to a new wiring harness from your headunit because there are two different ones. One for basemodel systems and one for Bose, Monsoon, etc
    3. If you have a basemodel GP then you don't have the center channel cut out in your dashboard.
    My advice is (just like everyone elses) save up some money and get a 4channel amp and some aftermarket speakers.....you will be doing justice to those two beast that you have in the trunk. Believe me its cheaper than you think to get better sound than that crappy Monsoon
  14. #14 Re: Upgrading Speakers from base to monsoon???
    Apr 2011
    Cleveland,OH
    Yes Basemodel GP's have tweets
  15. #15 Re: Upgrading Speakers from base to monsoon???
    Nov 2011
    Decatur
    yeah there ate tweeters in the base. so what kind of cheap amp and speakers do you guys suggest? cheap but get the job done, would be kinda cool to get pioneer ones because my subs and head unit are both pioneer although my amp is the hifonics Brutus series
  1. Installing Factory Monsoon Headunit w/ XM - in base model Grand Prix?
    By extreme in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2011, 06:34 AM
  2. Coupling Questions; upgrading speakers
    By trapper1306 in forum General Tech Discussion
    Last Post: 11-20-2010, 03:38 PM
  3. Can I replace the Monsoon speakers?
    By jstevanus in forum Audio, Security & Visual Electronics
    Last Post: 06-25-2010, 07:50 AM
  4. Replacement Monsoon Speakers
    By bilak09 in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2010, 07:40 PM
  5. 04 GTP Monsoon rear (JUNK) speakers.
    By 04compgtp in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2009, 11:36 AM
