Thread: Dome light assembly removal 04+
Results 1 to 4 of 4
  1. #1 Dome light assembly removal 04+
    Michigan
    What is the easiest way to drop the dome light assembly out of the headliner so I can drill holes in it for switches? I'm assuming just pull down but I don't want to just yank and break anything
  2. #2 Re: Dome light assembly removal 04+
    GT Level Member jmoore4294's Avatar
    You need to remove the lens covers and there are 2 phillips head screws on each side you need to remove. After that it's just a few clips that hold it in. Pull it down and unhook the wiring harness.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  3. #3 Re: Dome light assembly removal 04+
    Michigan
    Thank you. I'm assuming pop the lenses out with a flathead?
  4. #4 Re: Dome light assembly removal 04+
    Yeah. A relatively small flat head if you have it. Like a jewelers screwdriver if you got it.
  1. need help with rear hub assembly removal 97 gtp
    By tiedye in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2011, 12:27 PM
  2. Dome Light!
    By RaiderGT in forum The Rant Forum
    Last Post: 02-27-2011, 12:41 PM
  3. map dome light
    By wking2 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2010, 05:34 PM
  4. Best tools for hub assembly removal?
    By TronCarter in forum General Tech Discussion
    Last Post: 08-03-2009, 10:23 PM
