Thread: 8'' midbass in the front?
Results 1 to 11 of 11
  1. #1 8'' midbass in the front?
    SE Level Member Tremayne0126's Avatar
    Aug 2011
    Miami, FL
    So like i stated im new and one main reason i was attracted to the 04+ GP is the flat base of the door speakers so if cut properly could a 8'' midbass fit? anyone has tried?
  2. #2 Re: 8'' midbass in the front?
    Topeka, KS
    I haven't seen this done yet but you could be a guini pig. If you could get some 8's up in there that would sound really good!
  3. #3 Re: 8'' midbass in the front?
    Aug 2011
    Miami, FL
    lol. ill go for it i dont see any bad coming out of this a new door panel thats all
  4. #4 Re: 8'' midbass in the front?
    Topeka, KS
    The mount for the speaker is behind the door panel anyways so let us know how it turns out.
  5. #5 Re: 8'' midbass in the front?
    You'll want an enclosure.
    Preferably made of MDF.
    Door will rattle to death and leak otherwise.
  6. #6 Re: 8'' midbass in the front?
    Aug 2011
    Miami, FL
    see i know the mount for the speaker is behind the door my overall plan is to remove that mount put is a 8'' baffle and cut the door panel itself open to like 9-10'' then drop mdf in the to make the difference then drop the speaker in that to make it look flush mounted
  7. #7 Re: 8'' midbass in the front?
    Don't cut the door.
    The skin panel is okay, but not the door.
    And if the driver is open to the door, there is no point.
  8. #8 Re: 8'' midbass in the front?
    Aug 2011
    North Jersey
    Quote Originally Posted by Tremayne0126 View Post
    just make sure you spray paint any mdf that you use or coat it with fiberglass resin. it DOESN'T like to get wet.
  9. #9 Re: 8'' midbass in the front?
    Feb 2009
    Virginia
    Quote Originally Posted by banks8604 View Post
    Or you use a cutting board from walmart :>
    11 is louder than 10!
  10. #10 Re: 8'' midbass in the front?
    Chilliwack BC
    subscribed....if your doing it there better be pics !!!
  11. #11 Re: 8'' midbass in the front?
    Aug 2011
    Miami, FL
    ill do a whole build log
  1. SE Front Lip!
    By ray4was in forum Visual/Body Modifications
    Last Post: 01-08-2011, 02:57 AM
  2. Front end
    By Independentvice in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2009, 01:11 AM
  3. Who's that in front of my GXP?
    By Injun #4 in forum Off Topic Discussion
    Last Post: 10-01-2008, 07:06 PM
