Thread: Aftermarket Amp and Sub With Stock Stereo
Results 1 to 20 of 20
  1. #1 Aftermarket Amp and Sub With Stock Stereo
    Jul 2011
    Ontario
    I am picking up my 2006 Grand Prix tomorrow that we just bought. It has an in dash navi systen and I was wondering if I can add an amp and subs to it? If so, how hard is it?
  2. #2 Re: Aftermarket Amp and Sub With Stock Stereo
    Omaha, NE
    Easy. Tap the speaker wires for RCA cables, and install the rest just like any other sub/amp setup. DONE.
  3. #3 Re: Aftermarket Amp and Sub With Stock Stereo
    GTP Level Member
    springfield IL
    ^^^^^^^^^ and it will sound like a warm pile of poop!!
    is the navi an aftermarket deck?? alpine pioneer kenwood.....??
  4. #4 Re: Aftermarket Amp and Sub With Stock Stereo
    Pennsylvania
    Quote Originally Posted by tc300 View Post
    Hm, mine sounded good. I had the settings a bit off at one point and it caused the trunk lid to flex when it hit. Maybe tuning is just harder this way. I dunno.
  5. #5 Re: Aftermarket Amp and Sub With Stock Stereo
    Jul 2011
    Ontario
    It is the stock deck.
  6. #6 Re: Aftermarket Amp and Sub With Stock Stereo
    Jul 2011
    Ontario
    So are you suggesting there is no other way to run subs to factory unit?
  7. #7 Re: Aftermarket Amp and Sub With Stock Stereo
    GTP Level Member
    springfield IL
    Quote Originally Posted by kodeblue View Post
    you can but dont expect much.....you can have $5k in subs and amps, if the signal is shiity it will sound like it!
    save up and get a good deck....
  8. #8 Re: Aftermarket Amp and Sub With Stock Stereo
    SE Level Member mlasnoski's Avatar
    Jun 2010
    Marquette, Michigan 49855
    Stock Navigation....jealous. I have an 04 GTP CompG without Monsoon even. I got scammed =p Why couldn't I have the Monsoon and Digital climate =p It has everything else GM ever decided to put in our cars. Luck of the draw I guess.
    Feel lucky you have the stock nav. those units are mind boggling expensive!
  9. #9 Re: Aftermarket Amp and Sub With Stock Stereo
    Jul 2011
    Ontario
    Quote Originally Posted by mlasnoski View Post
    I haven't really had much time to play with the navi yet but I am sure I will like it. I do wish though that I could play MP3's. By the way, I don't have the digital climate either lol.
  10. #10 Re: Aftermarket Amp and Sub With Stock Stereo
    Jun 2010
    It's interesting how GM would put every option known to man in the cars and then just not put a fancier option in when its already got bells and whistles. I understand that sometimes its a dealer installed item so they can sell the car higher. I wished I had the 6-disc monsoon system. I am glad I have Xm Radio built in. I drove two other cars for a very long time with extra equipment always around. I like stream lines and orignal looking equipment. =)
  11. #11 Re: Aftermarket Amp and Sub With Stock Stereo
    Pennsylvania
    Monsoon system is a crutch that keeps people from getting a higher quality system. I would know.
  12. #12 Re: Aftermarket Amp and Sub With Stock Stereo
    Jul 2011
    Ontario
    Where is the 6 cd located, is it in the trunk?
  13. #13 Re: Aftermarket Amp and Sub With Stock Stereo
    GTP Level Member simbah's Avatar
    Lala land
    On the Monsoon the 6 disc changer is in dash within the HU.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  14. #14 Re: Aftermarket Amp and Sub With Stock Stereo
    May 2008
    Winnipeg, MB
    he will have to take out the factory navigation for a "deck" then loose steering wheel controls and need a security bypass module
    to original poster, does your stereo have a factory amp in the trunk?
    2007 Pontiac Grand Prix
  15. #15 Re: Aftermarket Amp and Sub With Stock Stereo
    Jul 2011
    Ontario
    Quote Originally Posted by tod1d View Post
    I have not yet seen a factory amp in the trunk, at least not without moving any carpet to see. I do have a Kenwood DVD deck in my Grand Am that is available now but I do like the on board navi and was hoping to keep the current deck because of it.
  16. #16 Re: Aftermarket Amp and Sub With Stock Stereo
    May 2008
    Winnipeg, MB
    the monsoon amp is located under the rear deck inside the trunk, if you can't see it right away when you look inside the trunk at the back, in the middle, at the top, its not there
    so after you put in a sub, you will have very weak mids and highs, they will be your next area you will want to upgrade, just opening up a huge can of worms if your asking me
    lots of work and money for better sound, but if thats very important then go for it
  17. #17 Re: Aftermarket Amp and Sub With Stock Stereo
    Jul 2011
    Ontario
    I did see a monsoon amp located where you said. I think the speakers have been upgraded. they are 3-way JVC 290w. Is that what is stock?
  18. #18 Re: Aftermarket Amp and Sub With Stock Stereo
    Nov 2008
    Waterloo, Iowa
    JVC anything is a cheapo piece of equipment. Definitely not stock.
  19. #19 Re: Aftermarket Amp and Sub With Stock Stereo
    May 2008
    Winnipeg, MB
    no, stock speakers are delphi two way I believe, anything other then that should be better
  20. #20 Re: Aftermarket Amp and Sub With Stock Stereo
    SE Level Member Shang TI's Avatar
    Austin TX
    If you don't want to get rid of the stock navi get http://www.crutchfield.com/p_236REQ5..._req5&skipvs=T that its an amazing device.
  1. Aftermarket Stereo Problems?
    By RedFace in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2011, 01:23 AM
  2. Keeping factory amp with aftermarket stereo
    By 90oddz in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2010, 05:37 PM
  3. Installing aftermarket stereo
    By jrdgz85 in forum Audio, Security & Visual Electronics
    Last Post: 03-24-2010, 08:39 AM
  4. Aftermarket stereo in 06 GP with Monsoon
    By GXP Bill in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2009, 01:23 PM
  5. Static in Aftermarket Stereo
    By KobAil in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2009, 12:19 PM
