Thread: 03 GTP yellow wire going through shifter cable grommet???
Results 1 to 7 of 7
  1. #1 03 GTP yellow wire going through shifter cable grommet???
    Jul 2011
    indiana
    I have an 03 GTP i have a yellow wire going through the firewall that comes from the ecu in airbox. it broke off when i was installing sub wiring today and i have no idea where it goes inside vehile please helppp
  2. #2 Re: 03 GTP yellow wire going through shifter cable grommet???
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    re solder it?
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  3. #3 Re: 03 GTP yellow wire going through shifter cable grommet???
    he said he cant find it.
    i would keep trying, rip the carpet back and dig in there and start looking for the same color wire
  4. #4 Re: 03 GTP yellow wire going through shifter cable grommet???
    Houston
    ?? Need a pic, cuz all the wires coming from the pcm are wrapped pretty well and are really tough to "break" just running the power wire.
  5. #5 Re: 03 GTP yellow wire going through shifter cable grommet???
    Jul 2011
    indiana
    Well the wire pulled through the firewall and broken not by the pcm. it is a single wire with its own wire loom. My buddy has an 01 GtP and his does not have this wire.
  6. #6 Re: 03 GTP yellow wire going through shifter cable grommet???
    Quit making multiple threads...I'm moving this to the electrical section anywho...
  7. #7 Re: 03 GTP yellow wire going through shifter cable grommet???
    Jul 2011
    indiana
    Update wire is connected to pin 21 on ecu connector. I beleive this is the performance shift wire. where does this wire go inside the car?
  1. Can you identify this shifter cable?
    By mtrmes02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2010, 03:29 PM
  2. Replacing Shifter Cable
    By twig123 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-21-2009, 12:40 PM
  3. Broke my shifter cable
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-30-2008, 09:33 PM
  4. Replacing the shifter cable
    By Zef_66 in forum General Tech Discussion
    Last Post: 01-25-2008, 01:12 PM
