So I was in my gp and randomly the data screen and ac/heat control screen went out, any suggestions.
Have you checked fuses?
I have checked the fuses, I looked at all the wires coming out of both units and I switched out my ac/heat controller with my old one to see if the one I put in a while ago was shorted out and still is the same.
I know some guys have had this happen to them and it was there ignition switch anyone know if that might be it?
I had the same issue. Found no power going to these items so from reading figured it was the ignition switch. It was random too. Replaced the switch and everything worked like a charm and has every since! (Been two years)
Good luck!
