Thread: what should i look for to fix this?
Results 1 to 10 of 10
mezzoni what should i look for to fix... 06-09-2011, 07:51 PM
mezzoni Re: what should i look for to... 06-11-2011, 06:32 AM
simbah Re: what should i look for to... 06-11-2011, 07:22 AM
I800C0LLECT Re: what should i look for to... 06-11-2011, 05:46 PM
tc300 Re: what should i look for to... 06-13-2011, 01:23 AM
mezzoni Re: what should i look for to... 06-11-2011, 10:18 PM
I800C0LLECT Re: what should i look for to... 06-12-2011, 10:25 AM
mezzoni Re: what should i look for to... 06-12-2011, 10:13 PM
tc300 Re: what should i look for to... 06-13-2011, 01:24 AM
  1. #1 what should i look for to fix this?
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    recently i put in a pioneer 4300 headunit, infinity door and rear 6x9 speakers, and a 2000 watt lanzar amp. my problem is the headunit makes a noise and it goes in like 1 or 2 second increments. i can see that it is a plastic gear spinning inside the headunit box. also the rear speakers have a thumping sound of the bass that is in sync with the spinning of the gear in the headunit.
    this happens with the car on or off. lights dont dim when the bass hits hard. i have a 8 guage wire running to the amp... im not sure where to start to diagnose the problem. any ideas? thanks
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  2. #2 Re: what should i look for to fix this?
    Nov 2009
    Milford, CT
    no ideas from anyone???
  3. #3 Re: what should i look for to fix this?
    GTP Level Member simbah's Avatar
    Lala land
    First you should have bigger wire for powering that amp more like 4 gauge or even 1/0 gauge would be preferred. 8 gauge is way too small for 2000 watts.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: what should i look for to fix this?
    Feb 2009
    Virginia
    Quote Originally Posted by simbah View Post
    If he's burping or something else I might agree. The only issue he might have is heat. Make certain that the fuse isn't getting too hot or over heating. If the wire insulation looks like it's "melting" or "burning" on the edges then you need to upgrade your wiring.
    Honestly I really don't know where to start with your install so I didn't want to answer. I think you need to start reading and educating yourself on a lot of different things. Pick one topic and we'll start there.
    11 is louder than 10!
  5. #5 Re: what should i look for to fix this?
    GTP Level Member
    springfield IL
    FYI, that amp is more like 1200.. not even close to 2k!!
  6. #6 Re: what should i look for to fix this?
    Nov 2009
    Milford, CT
    thats the one thing i regret is not really knowing enough and kinda got in over my head i think. and im willing to learn anything im just a super slow reader. im smart just read slow so when i see a huge big long thing with tons of information i get discouraged i think. throw the basics at me in semi-simple terms and i feel i can catch on. sorry if im being a PITA
  7. #7 Re: what should i look for to fix this?
    Feb 2009
    Virginia
    First thing I have to say is check all of your grounds. If your head unit is grounding properly then it will find other paths to accomplish the task. So with that said, is there any "alternator noise"? If you don't have alternator noise but you are hearing the head unit moving parts then the issue is probably within the head unit itself.
  8. #8 Re: what should i look for to fix this?
    Nov 2009
    Milford, CT
    no there is no alternator noise, it doesnt go with the pitch of the engine or anything like that. although today i was driving and the noise there, nor was it yesterday, which is the first time it hasnt been there and ive had it installed for over a month now probably. im confused as to why it just went away but as long as its gone i cant complain all that much
  9. #9 Re: what should i look for to fix this?
    GTP Level Member
    springfield IL
    unless its an old school lanzar with a zed board... LOL :->
  10. #10 Re: what should i look for to fix this?
    GTP Level Member
    springfield IL
    pioneers have grounding issues.... its prolly the deck and where its grounded.
    who installed it?
fix
