Thread: 04 with whining noise from speakers?
Results 1 to 7 of 7
  1. #1 04 with whining noise from speakers?
    Apr 2011
    Ohio
    I just installed aftermarket speakers and an amp and it started out with no noise but then i went to mount it upside down and then it got a horrible whining noise. The noise gets louder as i give it more gas but it also makes the noise when the key is just on acc. I have moved the ground to several places and got it all down to bare metal but still makes the noise. So i have no idea what could be causing the noise. The power wire is connected to the battery terminal(also tried the fuse box in the motor area) and the power is ran seperate from everything else. The turn on wire, speaker wires, and rca wires are all ran down the driverside while the power is ran down the passenger side. So how do i get rid of the whining noise?
  2. #2 Re: 04 with whining noise from speakers?
    GTP Level Member simbah's Avatar
    Lala land
    Exactly where is it grounded too. A great place to ground is a strut mount bolt.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: 04 with whining noise from speakers?
    Houston
    How good are your RCA's? If they're cheap and not shielded well, that remote line can cause noise.
  4. #4 Re: 04 with whining noise from speakers?
    Apr 2011
    Ohio
    They are cheap walmart ones so that could be the problem...im checking the amp right now. And it is grounded to the trunk floor. I just sanded away some paint and primer.
  5. #5 Re: 04 with whining noise from speakers?
    Feb 2009
    Virginia
    Cheap RCA's aren't any better than $1000 RCA's. I promise.
    11 is louder than 10!
  6. #6 Re: 04 with whining noise from speakers?
    Pennsylvania
  7. #7 Re: 04 with whining noise from speakers?
    Apr 2011
    Ohio
    I found it was the amp that was causing the problems.
  1. Whining Noise?
    By BwolfGT in forum General Tech Discussion
    Last Post: 06-15-2013, 09:44 PM
  2. Supercharger Whining noise very loud
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2011, 07:25 AM
  3. Whining noise coming from alternator maybe?
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2010, 11:50 PM
  4. Whining Noise
    By silo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:50 AM
  5. Whining Noise
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2009, 11:23 AM
