Thread: Speaker Help
Results 1 to 9 of 9
  1. #1 Speaker Help
    Feb 2008
    Hi 2001 grand prix gt after maket
    Sony cdx-gt50w
    kicker L5
    kenwood 9103d mono amp
    I just purchased new kenwood 6x9 for the rear deck how can i hook these up to the amp so that the subwoofer and the back are being powered by the amp I changed out the amp with a older two channel and dont think i'm doing it right they sounded like crap. I just need some good advice from smart people thanks for the help
  2. #2 Re: Speaker Help
    Saraland Alabama
    are you using a sub out on the radio? What 2 channel amp is it?
  3. #3 Re: Speaker Help
    Feb 2008
    Yes i am using the sub out on the head unit. I have an older pioneer two channel amp that is stable down to two ohms and the subs are 4 ohms also still have the kenwood 9103d 1600 watt mono amp
  4. #4 Re: Speaker Help
    Saraland Alabama
    if your using sub out to 6x9's that is the problem, wrong frequencies they will distort pretty quickly
  5. #5 Re: Speaker Help
    Feb 2008
    What is the best way to hook it all up. Like i said earlier I have a sony heaad unit and two kenwood 6x9 speakers in the rear deck. Also have 1 kicker l5 subwoofer and a kenwood 9103d mono amp. I want the loudest systm possible with what i have any ideas. thanks
  6. #6 Re: Speaker Help
    Saraland Alabama
    use the rear preouts for the amp on the 6x9's be sure to have a good distribution block for power, and I like to run a relay when doing multiple amps on the remote turn on to keep from burning it up
  7. #7 Re: Speaker Help
    Feb 2008
    What do you mean the rear preout? Where do i hook the wires from the back of the 6x9 to. Also can i hook up the factory wires to the rear speakers and then aslo hook up my own wires to the rear speakers and the amp. thanks for the help
  8. #8 Re: Speaker Help
    Saraland Alabama
    you need to pull the radio out, and run an rca line from the radio to the amp, then the 6x9's hook to the amp
  9. #9 Re: Speaker Help
    Feb 2008
    thank man for all your help i will do this tonight and let everyone know like i said i really appreciate it thanks
  1. New speaker help
    By 98gpgt98 in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2008, 10:37 PM
  2. stock speaker sizes
    By hotshot in forum Audio, Security & Visual Electronics
    Last Post: 06-16-2008, 06:06 AM
  3. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
