Thread: 2008 Grand Prix Question
Results 1 to 17 of 17
Masonveatch 2008 Grand Prix Question 02-28-2011, 12:55 PM
michaelbm Re: 2008 Grand Prix Question 02-28-2011, 04:11 PM
Masonveatch Re: 2008 Grand Prix Question 03-01-2011, 01:01 AM
michaelbm Re: 2008 Grand Prix Question 03-01-2011, 06:15 PM
Masonveatch Re: 2008 Grand Prix Question 03-02-2011, 10:20 PM
matt5112 Re: 2008 Grand Prix Question 03-05-2011, 01:17 PM
Masonveatch Re: 2008 Grand Prix Question 03-05-2011, 02:38 PM
matt5112 Re: 2008 Grand Prix Question 03-05-2011, 04:22 PM
michaelbm Re: 2008 Grand Prix Question 03-06-2011, 12:16 AM
Masonveatch Re: 2008 Grand Prix Question 03-09-2011, 10:09 PM
michaelbm Re: 2008 Grand Prix Question 03-10-2011, 10:39 PM
Masonveatch Re: 2008 Grand Prix Question 04-01-2011, 10:22 AM
michaelbm Re: 2008 Grand Prix Question 04-02-2011, 12:21 PM
  1. #1 2008 Grand Prix Question
    Kansas
    Ok, so i have been investigating on why my car did not have Onstar, since it was supposed to be standard on my car. GM customer service said that when the fleet order was processed, they remove onstar from my car. Now today, i found the wiring for the rearview mirror still up in the inside roof cover. Can i get an Onstar mirror and the antenna and hook onstarr back up on my car or is it a little more difficult than this? Thanks!
  2. #2 Re: 2008 Grand Prix Question
    New Brunswick
    If you have the 2 white plugs that would go to the onstar module up inside the dash it will be very easy. Just look under the center of the dash ahead of the center console and you will see them if you got em. Just above where the wiring harness goes to the center console.
    If you got those two connectors you may even have the antenna wiring as well.
    I added it from scratch on my 04 by changing out the dash harness while i was adding other options and could not get onstar to recognize my car as it really was since the module was from a wrecked car, however im sure if you get higher up tecnical at onstar or maybe the dealer reflash the onstar module you can get it to match your vin and everything. Just my 04 ended up getting wrecked so i nveer got that far.
  3. #3 Re: 2008 Grand Prix Question
    Kansas
    the wire's are up in the ceiling by the rearview mirror, evidence that there was the mirror there.
  4. #4 Re: 2008 Grand Prix Question
    New Brunswick
    I wouldnt say it was there, Just it was left out at the assembly line, you can confirm this by looking at the service parts label under the carpet/spare tire cover. If you have RPO code UE1 it did have it, if you dont have this code and have something like UE0 or similiar it was left out to begin with.
    All roofharnesses that had the lamp group option that included the rear interior lamps with switches automatically come with the plug just up inside the headliner.
    You have the headliner harness for onstar which you confirmed, The body harness already has the onstar wires in it already since i know they do from experience, so now the last thing to confirm is if the dash harness has the wires which is why we need to know if those two plugs exist under there.
    Let us know what you find
    If you have these two plugs you will need mainly the onstar module, mirror, and antenna. For the antenna you will have to make the mounting holes in the roof to accept the antenna unless you have an xm antenna which case there would already be holes and just need to swap the antenna.
  5. #5 Re: 2008 Grand Prix Question
    Kansas
    Ok, i found the white connector where you said it would be, but i found only one, behind and under the dash. Is there another spot where the other connector would be? Thanx for the help.
  6. #6 Re: 2008 Grand Prix Question
    Moved.
    Try to post in the appropriate section.
    Thanks.
  7. #7 Re: 2008 Grand Prix Question
    Kansas
    Moved to what? i have not been on a forum before. sorry.
  8. #8 Re: 2008 Grand Prix Question
    I moved your thread to the appropriate section for the type of thread you've created.
    Helps other people find it easier.
  9. #9 Re: 2008 Grand Prix Question
    New Brunswick
    Did you have a look to see if the other one is taped up somewhere near? how many pins does the one you have got?
  10. #10 Re: 2008 Grand Prix Question
    Kansas
    Does anyone have a diagram of where all the wiring for a 2008 Grand Prix? Like the Onstar Wiring, and where to look for it all at? Thanks!
  11. #11 Re: 2008 Grand Prix Question
    New Brunswick
    PM me your email address and i'll send em over to you, i got connector pinouts plus diagrams.
  12. #12 Re: 2008 Grand Prix Question
    Kansas
    Ok, i am not going to do the onstar thing for a while, due to it's expensive. I was wondering if anyone knows how to hook up the compass and thermometer in the grand prix. I have the 3 buttons right now. Do i need to have the 5 buttons for it to work?
  13. #13 Re: 2008 Grand Prix Question
    New Brunswick
    The 5 button DIC with temp and compass is very easy to do.
    All you need is the front temp sensor that goes behind the bumper/grill,
    the compass sensor that goes under the rug under the back window, and the 5 button dic with the matching trim.
    The best place to get this stuff is from a junkyard locally as most online sellers realize the demand and the price is usually 200+ dollars.
    If you cant get the temp sensor off the wrecked car due to being smashed to badly the dealer has em for about 10 bucks. The car has all the wiring already regardless of what trim it is.
    I know of one person who couldnt find the connector in the back for the compass module but im guessing it should be there, To look for it you can reach your hand in from in the trunk where the audio amp would have been between the two speakers and feel around for the unused connector, Its around the left speaker.
    On the onstar topic did you manage to find that second white connector?
  14. #14 Re: 2008 Grand Prix Question
    Kansas
    Yes, i think i did find the 2 connectors, but the cost of having to put the Onstar items on was too much. On the compass thing, i found the connector, but not the wires in there. Also, how do i find the temp sensor? do i have to pop off the grills to get to it?
  1. 2008 Grand Prix GXP 5.3L
    By toolman in forum Introductions/Noob Questions
    Last Post: 05-17-2010, 06:30 AM
  2. 2008 Grand Prix GXP
    By kevinhurley in forum Introductions/Noob Questions
    Last Post: 01-22-2010, 10:00 AM
  3. 2008 Grand Prix
    By firehawk in forum General Tech Discussion
    Last Post: 11-24-2008, 06:43 PM
  4. 2008 grand prix
    By KingOfTheSouth in forum Off Topic Discussion
    Last Post: 11-05-2008, 07:47 AM
