Thread: infinity kappa vs. reference
Results 1 to 8 of 8
  1. #1 infinity kappa vs. reference
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    so im pretty sure kappa's are better, but can you run them without an amp or no? i read that you cant run the kappa's without one and can run the references withouth one. i just want a second opinion
    thanks
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  2. #2 Re: infinity kappa vs. reference
    more expensive ones are generally better made, but not always.
  3. #3 Re: infinity kappa vs. reference
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    Quote Originally Posted by mezzoni View Post
    thanks
    You need an amp for kappas in most cases or they dont sound like they should but the difference in the reference and kappa is night and day kappas ussually come with external crossovers.
  4. #4 Re: infinity kappa vs. reference
    if you're serious about sound you would already have an amp anyways?
  5. #5 Re: infinity kappa vs. reference
    Jul 2010
    Dubuc, SK
    I use kappas, and they sound excellent on an amplifier of about 75 rms watts each or so.
  6. #6 Re: infinity kappa vs. reference
    Nov 2009
    Milford, CT
    well the thing is i wanna keep my costs down as low as possible while still getting the best quality. betterly put i wanna get the best door and rear deck speakers i can without going to an amp. the woman at the local stereo shop said infinity's are really tho only ones that can pump out the tones of country and rock songs without an amp, but she didnt tell me which ones. im not looking to go to an amp or subs. and i already bought the pioneer 4300 headunit
  7. #7 Re: infinity kappa vs. reference
    Feb 2009
    Virginia
    Power is power. It doesn't matter where it comes from these days. Music is dynamic and the internal amp on a radio doesn't always keep up well with that due to size and heat constraints.
    What you want to do when choosing speakers is pick out the highest sensitivity you can if you're worried about output, while using the deck power. Majority of time you end up over driving the internal amp and then you blow speakers because it's putting out a clipped signal or there's a lot of distortion(most people don't notice either).
    11 is louder than 10!
  8. #8 Re: infinity kappa vs. reference
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Buy cheaper aftermarket speakers, but get an amp with em. Your will get better sound.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  1. Can you limit power draw through smaller wire? (no, bad idea for reference)
    By nik12937 in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2010, 09:35 PM
  2. The Master Vehicle Bolt Pattern Reference Website!
    By jcrules78 in forum Tires & Wheels
    Last Post: 03-19-2010, 03:44 PM
  3. Infinity G35
    By BoostedComp in forum Track Sessions and Kills
    Last Post: 12-10-2009, 03:40 PM
