Thread: Static and cracking sound from door and dash speaker
Results 1 to 12 of 12
  1. #1 Static and cracking sound from door and dash speaker
    Apr 2011
    New Hampshire
    I'm getting very frustrated with this static/cracking sound coming from driver's side speaker. I removed door panel and disconnected speaker only to now have static sounds coming from dash speaker. This sound continues even when key removed from ignition. Could this be a blown amplifier or are both speakers blown?
    If it is amplifier, can you tell me how to remove so I can install another one?
  2. #2 Re: Static and cracking sound from door and dash speaker
    Omaha, NE
    What year is your car? My 04+ also does this when the doors are open without the key in the ignition.
  3. #3 Re: Static and cracking sound from door and dash speaker
    Apr 2011
    New Hampshire
    Mine is a 2006
  4. #4 Re: Static and cracking sound from door and dash speaker
    Pennsylvania
    This seems to be an 04+ Monsoon thing. If you wait a few minutes with the key out, the amp will turn off and the speakers will stop making noise. I haven't seen any information identifying it as the speakers or the amp.
  5. #5 Re: Static and cracking sound from door and dash speaker
    Apr 2011
    New Hampshire
    The sound will not stop after key is removed. I've actually opened the door in the morning and the sound is still there.
    I have had the left door speaker disconnected 1 day and so far NO static/cracking yet. I'm thinking blown speaker...but why would blown speaker make sound while no power???
  6. #6 Re: Static and cracking sound from door and dash speaker
    Pennsylvania
    You have to wait for the power to turn off. Trust me, it turns off if you wait. When you open the doors, you're introducing power (notice the lights went on?)
  7. #7 Re: Static and cracking sound from door and dash speaker
    Jul 2010
    Dubuc, SK
    This happens on my 04 as well. The sound gets worse when you add an aftermarket headunit with the adapter, and a seperate amp for the speakers... As far as I know there is no way around this, but it is normal.
  8. #8 Re: Static and cracking sound from door and dash speaker
    Apr 2011
    New Hampshire
    I ended up buying an aftermarket speaker (POLK DXI 650) and replaced the left door speaker. So far NO static/cracking sound.
    I'm going to replace the other door speaker today and hope this fixes problem.
  9. #9 Re: Static and cracking sound from door and dash speaker
    Jun 2011
    orland park
    hi, i was wondering if anyone knows how to replace the speaker in the dash
  10. #10 Re: Static and cracking sound from door and dash speaker
    GTP Level Member simbah's Avatar
    Lala land
    Pry off the cover, and unscrew the screws ,pull out speaker, disconnect said speaker, install is reverse directions. yes that easy
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  11. #11 Re: Static and cracking sound from door and dash speaker
    Jun 2011
    orland park
    thanks a lot! i really think it is the speaker, but i do hear static when car is off. heard it could be amp???
  12. #12 Re: Static and cracking sound from door and dash speaker
    Pennsylvania
    I saw that someone put in aftermarket speakers and the noise went away, so it seems that the issue would be the speakers, then.
  1. Door speaker info
    By Peirce1970 in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2011, 12:36 PM
  2. door speaker
    By PNIGZ in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2010, 04:07 AM
  3. frount speaker poping sound
    By kjohnson in forum Audio, Security & Visual Electronics
    Last Post: 08-28-2009, 08:17 PM
  4. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
  5. Door Chime/Speaker Problems
    By JBmiddy23 in forum General Tech Discussion
    Last Post: 12-20-2008, 10:46 AM
