Thread: Lincoln LS rearview mirror
Results 1 to 8 of 8
  1. #1 Lincoln LS rearview mirror
    Reynosa,Mexico
    Hi I got a hold of a rear view mirror with compass from a 2003 LS I was looking at it and it seems to wave the compass sensor on it do you think It can work if I just splice in the wires using the wires from the original auto dimming mirror on the Grand Prix?
  2. #2 Re: Lincoln LS rearview mirror
    i dont see why not but that would be cool though
    does all it take is a power source?
    SMGPFC Member #10
  3. #3 Re: Lincoln LS rearview mirror
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Is it a gentex mirror?
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  4. #4 Re: Lincoln LS rearview mirror
    St. Louis
    Yes, that should be a gentex mirror.
  5. #5 Re: Lincoln LS rearview mirror
    Feb 2010
    Oklahoma City, OK
    Just ordered my gentex a couple days ago and most if not all I was looking at just needed a hot 12 and a ground and the autodim and compass all will work.
  6. #6 Re: Lincoln LS rearview mirror
    Mirrors are all pretty easy. Most are standard and made by only a couple of companies.
    Heck my Regal has a Maxima/Murano mirror with Homeylink
  7. #7 Re: Lincoln LS rearview mirror
    Reynosa,Mexico
    Well I did plugged it in to a 12v power source And it seems to be working pretty fine even tho it was 7 pins on it I noticed that on the wire harness that came with it only has 3 hooked up Ignition, Ground and Reverse. Don't really care about reverse cause I think all it does is take the mirror off auto dim when you shift to reverse. I'll put it up ones I figure how to tame the original mirror off with out the metal brace come off the mirror.
  8. #8 Re: Lincoln LS rearview mirror
    Reynosa,Mexico
    OK already mounted the mirror up works pretty good didn't ever have to cut wires just pryed out the cables of the cars connectors and switched them out for the cables on the mirrors connector. everthing works fine mirror and compass. This is the mirror set up on the GP.
  1. Rearview Mirror Removal
    By RedGTDT in forum General Tech Discussion
    Last Post: 08-17-2011, 11:05 AM
  2. Auto Dim Rearview Mirror
    By Suaveat69 in forum 04+ Specifics
    Last Post: 08-10-2010, 09:19 PM
  3. How do i add a temp/compass rearview mirror?
    By themagicdustman in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2010, 01:46 AM
